having minor clutch issues. need some help.
Old Aug 7, 2009 | 12:03 PM
OneCleanS14's Avatar
Default having minor clutch issues. need some help.
ok. well last night as i was leaving my house, i was driving down the street shifting from 1-2-3-4. but as i was lifting my foot off the pedal after shifting into 4th, i noticed that there wasnt alot of pressure on the pedal. so curious to see if i felt that right, i pushed down on the pedal and it was really really soft, and the clutch was engaging almost all the way to the bottom. so i pushed down on it a few more times but it remained the same. so today i bled the clutch because i thought it was just some air bubbles. some bubbles did come out. but the pedal only got a little stiffer. only a slight difference. so i bled it several more times, but there were no more bubbles. now the pedal is still soft, and still engages almost all the way to the bottom, and im out of ideas. so now i need some help. any answers/suggestions will help. thanks.
KA-T.
Enthalpy Tuned.
Old Aug 7, 2009 | 12:35 PM
NeedCAforS13's Avatar
TOTALLY AWESOME.
Do you still have the clutch damper box installed?
(O=O/-ROUGH WORLD-\O=O)
Old Aug 7, 2009 | 12:39 PM
where is that at?
KA-T.
Enthalpy Tuned.
Old Aug 7, 2009 | 12:41 PM
TOTALLY AWESOME.
THE GARAGE GUIDES - Remove Your Clutch Damper
Old Aug 7, 2009 | 12:42 PM
TOTALLY AWESOME.
Its very difficult to bleed the clutch properly with the damper in place. Just remove it, and bend the hard line. Easy.
Old Aug 7, 2009 | 12:57 PM
thanks sean! ill check it out.
KA-T.
Enthalpy Tuned.
Old Aug 7, 2009 | 01:01 PM
TOTALLY AWESOME.
Also check the threaded rod that goes from the pedal to the clutch master under the dash. You can try adjusting that too... worst case is replace the slave/master and they're pretty cheap.
Are you losing fluid at all?
Old Aug 7, 2009 | 02:04 PM
SRH666's Avatar
supports radical habits
my clutch feel is awesome with the damper closed off
Old Aug 7, 2009 | 04:34 PM
Z28ricer's Avatar
Doesnt see what you did
  1. Fill reservoir to full level with brake fluid.
  2. Connect a transparent vinyl tube to air bleeder valve.
  3. Fully depress clutch pedal several times.
  4. With clutch fully depressed, open bleeder valve to release air.
  5. Close bleeder valve when pedal reaches floor.
  6. Repeat steps 3 through 5 until all air is bleed from clutch system.
  7. Bleed air from clutch piping connector according to steps 3 through 6.
  8. Repeat procedure several times to ensure all air is removed from clutch system.
  9. If clutch is still not fully operational (offers very little resistance), proceed as follows:
    R.I.P. Tim
    RB $200
    LS1 $250
    Old Aug 7, 2009 | 10:05 PM
    ^thanks! but what is the clutch piping connector exactly?
    KA-T.
    Enthalpy Tuned.
