gear shifting problem
Old Jan 15, 2009 | 07:09 PM
Silk_240's Avatar
Just Drive
Default gear shifting problem
ok i've been having issues with my ride as you can tell by my other recent post.
here is the issue: push the clutch in and try to shift but will not shift into gear sometimes.
other times i push the clutch in and it is difficult to shift the gears.
and then it will shift normally like nothing is wrong. please help me!!!!
i think my clutch is done-so
Old Jan 15, 2009 | 07:16 PM
OneCleanS14's Avatar
slave?
Old Jan 15, 2009 | 07:23 PM
b15mark's Avatar
Full time - Work/School
I 2nd check the slave. check your fluids constantly and never let that bitch run dry...
Hot Import Nights - $5 off online ticket sales! PROMO Code PEARL
Cressida - Traded || SX Hatch - Traded || SX Vert - SOLD
Old Jan 15, 2009 | 07:40 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
if it is ur slave thats a $15 fix, and if it is ur master that is a $35 fix
Drifting:
most fun you can have
with your pants on.
Old Jan 16, 2009 | 04:54 AM
Silk_240's Avatar
Just Drive
i have fluid in the res. how is an easy way to check the slave? or should i just buy a new one and replace it? I have a '92 s13
Old Jan 16, 2009 | 06:37 AM
longfellow2's Avatar
FORE:sight
The slave is bolted to the transmission, its the part that moves the shift fork. You can replace it since its cheap. But your main problem is cold weather, every 240 has this problem in cold weather untill the car gets warmed up. Other than that there really isnt much you can do about it.
Originally Posted by Epstein
Old Jan 16, 2009 | 08:15 AM
A-ron's Avatar
put some fresh 75w90 gear oil in it it wont be that bad.
thats what me and a friend did makes it feel better when the tranny is cold
Drifting:
with your pants on.
Old Jan 16, 2009 | 01:45 PM
Silk_240's Avatar
Just Drive
ok, going to replace the slave tomorrow, will keep yall updated. thanks for the insight
Old Jan 16, 2009 | 04:45 PM
Silvia-san's Avatar
fuck
when my slave went out on my 92 the clutch peddle just fell to the floor lol
USMC 3/2 KILO
PS3 GAMETAG: Silvia-san
http://forums.nicoclub.com/zerothread/253879
Old Jan 17, 2009 | 01:18 PM
Silk_240's Avatar
Just Drive
replaced the slave and nothing new. i've adjusted the clutch pedal and still nothing. while parked and at idle i could push the clutch pedal in and shift into 3,4,5 but not smoothly. going to replace the master cylinder and see what happens then
