gear shifting problem
Old Jan 19, 2009 | 06:29 AM
  #31 (permalink)
vertigo's Avatar
U and your 3rd dimension
Silk, does the clutch get stiffer when the tranny wont go into gear?
Rear brake only for use when front brakes squeak whilst slowing for hot bitches
Old Jan 19, 2009 | 11:13 AM
  #32 (permalink)
Silk_240's Avatar
Just Drive
^ nope
Old Jan 19, 2009 | 06:59 PM
  #33 (permalink)
Silk_240's Avatar
Just Drive
the problem was the plate that is inside the bellhousing where the throw out bearing rests and the input shaft goes through coming out of the tranny, that plate broke and it f'ed up the clutch at the same time. so if anyone has sr or ka trannies please let me know, i just need that plate.
Old Jan 19, 2009 | 07:01 PM
  #34 (permalink)
Jeff_TT's Avatar
Trying to keep a Z runnin
If you're talking about the shift fork that should be easily replaced with uot having to buy a new tranny.
"You will spend 10% of your money getting the first 90% of your Horsepower, but you will spend 90% of your money getting the last 10% of your Horsepower" Quote from an old racer guy I know!
Old Jan 19, 2009 | 07:07 PM
  #35 (permalink)
Silk_240's Avatar
Just Drive
not the shift fork, its a plate that is behind that where the shift fork and throw out bearing rest on. its bolted in by 5 bolts
Old Jan 19, 2009 | 07:09 PM
  #36 (permalink)
Jeff_TT's Avatar
Here's the shift fork...
CourtesyParts :: [30531] LEVER-WITHDRAWAL,CLUTCH - 240SX (S13) 1989-1994
If that's not it try here...
321 Transmission Case & Clutch Release :: Power Train :: Genuine Nissan Parts :: 240SX Parts (S13) 1989-1994 :: CourtesyParts.com
Old Jan 19, 2009 | 07:12 PM
  #37 (permalink)
Silk_240's Avatar
Just Drive
from that diagram, i need the 32110 part number, cover assembly front
Old Jan 19, 2009 | 07:57 PM
  #38 (permalink)
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
how an the hell did you break that-240SX CASE ASSY-TRANSMISSION
wow i think that you are better off buying a new tranny that has no grinds in it off here for less than $100
Drifting:
most fun you can have
with your pants on.
Old Jan 20, 2009 | 03:48 AM
  #39 (permalink)
Silk_240's Avatar
Just Drive
they the pilot bearing broke which gave the input shaft more play that lead to the breaking of that part. the part from the dealership is only $45
