Datsun Dreaming
Old Aug 31, 2010 | 10:24 AM
  #22351 (permalink)
LongFellow's Avatar
Please hold...
You can honestly believe that comparing an LS6 corvette motor to the one from a VK56 Titan motor is valid.
Team White Car 2010
  #22352 (permalink)
Z28ricer's Avatar
Doesnt see what you did
Your 560 HP Italia
17.1 MPG Combined
Corvette ZR1
638 HP
17 MPG combined
I just see 80 HP more, with the same fuel mileage.
And more honda-esque HP/Liter excuses.
Old Aug 31, 2010 | 10:25 AM
  #22353 (permalink)
box240mod's Avatar
tire eater
I have an LS1. its the bestest evar.
Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com!
Box on FB
Old Aug 31, 2010 | 10:27 AM
  #22354 (permalink)
LongFellow's Avatar
Please hold...
Originally Posted by Z28ricer
Yeah i'll tell you how that goes, just like the 320 HP vk56 vs the 405HP LS6
Or the 320hp VK56 and the 320hp LS1? How does that one work out.
Team White Car 2010
  #22355 (permalink)
Z28ricer's Avatar
Yeah, cause Infiniti cars are known to use the lowest output stuff nissan has around.
I gave you a MORE than fair comparison on the 5.3 "truck engine"
same power, less displacement, from the redneck pushrod motor
the lemans gtr vs the corvette
again same displacement, same power from a PUSHROD motor
Old Aug 31, 2010 | 10:29 AM
  #22356 (permalink)
Z28ricer's Avatar
So you want to use a 1997 engine, to compare to a 2004 engine
Like i said,
LS6, 2003, 405 HP, 400 ft lbs
Quit using a weak LSx example against the best VK you can find, apples to apples remember ?
Old Aug 31, 2010 | 10:33 AM
  #22357 (permalink)
LongFellow's Avatar
Please hold...
Your 560 HP Italia
17.1 MPG Combined
Corvette ZR1
638 HP
17 MPG combined
So a blown 6.2L v8 v.s 4.5L NA V8? What about comparing that with the LS7's 2.5L advantage? Doesnt work out too well there. The LS7 then should make over 700hp from factory since it has so much more displacement right? How would the gas milage work then? You also cant argue weight and height either because the 4.5 is one of the smallest v8's made.
Team White Car 2010
Old Aug 31, 2010 | 10:35 AM
  #22358 (permalink)
Z28ricer's Avatar
Again
HP wins races
MPG affects your wallet
Displacement, well you can make some good excuses with it huh ?
Over 700 HP from the factory, remember its a run of the mill daily driver, but hey $200 says a pulley change and you've got your 700 HP
  #22359 (permalink)
Epstein's Avatar
Retired
Oh really ?
Head flow doesnt matter to HP ?
Go figure, everyone out there buying ported head packages, they're just throwing money down the drain, because it doesnt allow for more power
You infer whatever you want, but I didn't say that head flow doesn't matter to HP. I said that HP is a better indicator of flow in general. Your static flow crutch argument is tired and you don't know enough about dynamics to back it up.
And since when is "swapping it into stuff" some kind of requirement for a good motor?
Oh yeah since you wanted to compare on the same displacement level
VK56DE 5.6L 315 HP / 390 Ft lbs
LS6 5.7L 405 HP / 400 ft lbs
Looks like even when not static, you OHC setup just got beat by 90 HP and 10 ft lbs, by a "redneck potato"
Ouch ?
Sweet, now we're talking tech!
BTW, VK56DE now makes 420 HP in the new M56. awww....
Old Aug 31, 2010 | 10:40 AM
  #22360 (permalink)
LongFellow's Avatar
Please hold...
Where are you getting your unrestricted out put numbers from? As far as I'm aware they're aren't any listed anywhere. And if they are running the same size restrictors then they both make about the same power unrestricted.
And its not the same displacement like I said FIA GT1 its 5.6-vk v.s 7.0-ls, both are restricted. Meaning both make more than that unrestricted and you have no clue which makes more so you cant argue that. All we know is they both make over 600hp unrestricted. But the GTR is faster and has a much smaller motor. The GTR actually has the smallest motor of the field by quite a bit. Everything else in that class is over 6.0L.
Team White Car 2010
