high output NA-KA
hmmmmm...
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
they have what 190hp or something like that NA. VVL nice. And you can pick one up for around 1500 a whole lot cheaper than having to build a motor and you still get more power.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
and you get the joys of no rwd transmissions bolting up to them
so, custom starter / modified bellhousing situation
for a motor that does , to the wheels, what a KA with intake and exhaust will do.
What a good choice! Lets throw the torque out the windows!
Be realistic, guys.
in order to make a motor that revs to 8000-8500 but with ap owerbgand only from 5500-8500 effective in a car like the 240sx you'd need to get closer ratio transmission and a much higher final drive, something like a 4.5 - 4.7 to make it nice and peppy. that's how the hondas work so well, is with gearing..
a taller first gear with much closer all of the other gears, and a good final..
too much work if you ask me; stop trying to reinvent the wheel.
Be realistic, guys.
rest in peace tim.
rest in peace tim.
i was saying "hmmmmm" to the whole idea of NA, not the sr20ve swap.
If you want 200+ hp, go forced induction. If you want NA, go v8.
Angry Video Game Nerd =
not everyone is into straight line so v8 is not an option. too much weight.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
not really...everyone over exadurates the weight of v8's...your adding maybe 75-150lbs tops to toss in an LT1, which has an iron block...LS1's are a bit lighter then an LT1. itd be like putting on a large turbo, and fmic setup for the most part.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
the cast iron is the problem. you dot want that even on the ka cause it still makes it nose heavy.
cant you use a sr20det block with a vvl head? put some high compression pistons in it and you have a strong bottom end. and use a sr20det trany and your set.
