Finally got ethanol kit working on blue car. but....
Old Jan 2, 2012 | 03:42 PM
  #31 (permalink)
lancerman's Avatar
its a relief that I can continue to play without a major step back. but just cant figure out where the problem lies. swapped in flaco ecu today with same result. going bonkers on this one...
my favorite quote
Old Jan 2, 2012 | 07:12 PM
  #32 (permalink)
Boost Demon's Avatar
Maybe try putting your normal UICP on until you get that injector driver box?
Old Jan 2, 2012 | 07:56 PM
  #33 (permalink)
lancerman's Avatar
I dont have injection wired in at the moment. the misfire is still there. no 2 injector just stops firing. I can plug in known good injector and it doesnt click. wiring problem of some sort. just doesnt make sense that the problem goes away when car is shut off for a minute. then it returns after 1-10 minutes of run time. tried a second ecu today and it made no change to problem.
my favorite quote
Old Jan 3, 2012 | 04:17 AM
  #34 (permalink)
JR.'s Avatar
JR.
Is those kind of problems that will make a dsmer part out his car, but knowing Jerry he will figure this out in a couple days.
98 talon awd automagic
Old Jan 3, 2012 | 04:44 AM
  #35 (permalink)
cjackson2802's Avatar
could your resistor pack be the culprit? only other thing that controls injectors is the mpi, ecu, cas right?
Old Jan 3, 2012 | 06:59 AM
  #36 (permalink)
lancerman's Avatar
was gonna try resistor pack today, that is a good possibilty
my favorite quote
Old Jan 3, 2012 | 07:08 AM
  #37 (permalink)
yeah most likely. you have hall effect cas, swapped ecu, and if it was mpi you wouldnt have power to any of the injectors
Old Jan 3, 2012 | 08:48 AM
  #38 (permalink)
lancerman's Avatar
had high hopes on the resistor pack. seems a failing one could cause same symptoms. but that didnt fix it.
my favorite quote
Old Jan 3, 2012 | 09:27 AM
  #39 (permalink)
Take the next step. Drive it until #2 stops firing, and then see if you're getting any power to the injector clip. If you are getting power but its not pulsing then its either CAS or break in a wire. If you're not getting power then maybe mpi relay? Ive had a similar problem before, never found the culprit...I unplugged my whole engine harness, plugged everything back in and never had the problem again...lol
Old Jan 3, 2012 | 03:17 PM
  #40 (permalink)
danameisoj's Avatar
you might have 2 different problems to occur this. (resistance or exposed wiring) or both combined.
electricity will follow path of least resistance. check to see if you have any exposed sections of that portion of the harness. Excessive resistance could cause this to happen. If its exposed it could ground itself to where ever its open rather than the circuit doing it job.
For the car to be working normally than shutting down its sounding like something is getting to hot and finding another way out or shutting itself down.
NATT Certified
