Finally got ethanol kit working on blue car. but....
Old Dec 28, 2011 | 06:08 PM
lancerman's Avatar
Originally Posted by wishiwasfast
Looks good Jerry! Wanna do mine?
Thanks. Cylinder head works takes time. I have 15 or so hours in this head. Could have spent more time. Thats why car had relatively stock head before. just spent over 500 in parts and 15 hours with an exceptional core as starting point. I see why most shops charge 1200-1600 for this type of work.
Didnt get much done today. had to work on other things. But spent 2.5 hours rebuilding the water neck.
my favorite quote
Old Dec 28, 2011 | 06:19 PM
THE_ONE's Avatar
*Turbo Interceptor*
Great work Jerry, keep it up!!!
Old Dec 28, 2011 | 06:41 PM
Tom N's Avatar
Non DSM.....DSM guy
Why is there a cap on the water neck?
Tom
Old Dec 28, 2011 | 10:18 PM
JR.'s Avatar
JR.
My colt had one of those too. I don't even know from what car those water necks are feom
98 talon awd automagic
Old Dec 28, 2011 | 10:29 PM
omgosh's Avatar
Looks like stock 2g to me.
Old Dec 29, 2011 | 12:43 AM
lancerman's Avatar
when I switched to 2G fluidyne radiator I switched to 2G style water neck.
for those not aware, the evo 1-3 comes with cap on radiator.
my favorite quote
Old Dec 31, 2011 | 07:33 PM
  #17 (permalink)
lancerman's Avatar
its alive. runs quite a bit different. will update sunday. happy new year to all!
my favorite quote
Old Dec 31, 2011 | 08:13 PM
  #18 (permalink)
THE_ONE's Avatar
*Turbo Interceptor*
Happy New Year!
May the old one die a tragic death and burn in hell forever!
Old Jan 1, 2012 | 06:11 AM
  #19 (permalink)
lancerman's Avatar
first thing I noticed were idle changes. idles smoother now. and before it wouldnt idle lower than 800 with biss screw all the way in. now it will idle at 600...first few drives with water not yet topped off were disappointing. trapped air in system increases detonation. knock tables looked pretty much the same. and car felt slower. boost curves looked different, with less boost at higher rpms. took a break and thought about all the subtle changes that were made.
cam gear settings were thrown off. more advanced now. old head was shaved about .030. this retards cam gears as head is closer to block the belt gets longer. compression is lower now. this head has never been shaved, old compression around 9.5 new at 9.0. and of course porting. poor porting can slow velocity and kill torque. and CAS had to be reset. so timing could easily differ by one degree.
made some tweaks to came gears and timing. trying to duplicate prior settings. and fruits starting to showing up. finally less knock spikes from 2/4. new best airflow numbers. old best was 50.3 lbs/minute. new best of 54 lbs/minute. AVCR relearning boost plots return to normal. same boost, same tune, less compression, and the car is FASTER. awe yes....
and now the power band doesnt feel 2.3 like. feels more like a 2.0 now. pulls much better high rpm. feels like the yellow car power band. power band is far more inviting. very happy with results and time spent.
old look. new head deserves fresh look.
which cover looks better?....I think I like the black.
my favorite quote
Old Jan 1, 2012 | 06:53 AM
  #20 (permalink)
THE_ONE's Avatar
*Turbo Interceptor*
Black
