High idle.. Need help!!!
Old Nov 12, 2011 | 08:43 AM
steves tr's Avatar
Default High idle.. Need help!!!
Ok i have a 1g talon tsi, its idling at 3k rpms. cant figure it out, need Help.
Old Nov 12, 2011 | 09:55 AM
lancerman's Avatar
idle that higher usually means intake manifold gasket is broken. the effect is like holding throttle plate open
my favorite quote
Old Nov 12, 2011 | 10:31 AM
steves tr's Avatar
Probly what it is but whats wierd is when i disconnect maf it idles normal, would that still happen if intake manifold gasket is leaking?
Old Nov 12, 2011 | 12:59 PM
steves tr's Avatar
Ok I took off the manifold gasket, its not broken its also the metal gasket. I was wondering can i reuse the gasket and slap some rtv on it? Or should i get a new one.
Old Nov 12, 2011 | 01:58 PM
Slow91Laser's Avatar
As long as the gasket is not bent or messed up im sure you can reuse it......
As far as the high idle i would replace the ISC, same thing happened to my car, if anything hit up the local junk yard and grab one, new ones cost a good chunk of change....
Just Another Stock Block DSM......
Old Nov 13, 2011 | 08:18 AM
steves tr's Avatar
Well, changed intake manifold gasket today, still high idle.. Go figure, but now i'm hearing a hissing noise coming from top on intake manifold right by the injectors i think it might be one of the o-rings that go on the bottom of injectors. hopefully its not the intake manifold gasket.
Old Nov 13, 2011 | 08:19 AM
steves tr's Avatar
Need to pressure test, but no compressor.
Old Nov 14, 2011 | 04:29 AM
cjackson2802's Avatar
just spray starting fluid or something flammable around the general area and it'll rev up alot higher for a quick second when you hit the leak.
Old Nov 14, 2011 | 05:23 AM
DarksideZ's Avatar
TR Balla Donor Supreme
First step would be to do a boost leak test and find your leak before randomly replacing seals and gaskets. Instructions on how to make a boost leak tester are in the thread below.
IC Pipe Tester
Let us know what you find out.
Old Dec 3, 2011 | 09:40 AM
steves tr's Avatar
found the problem the fiav was stuck open causing vac leak....got to love computer controlled vac leaks. idles at 1100 rpms now thank god.
Aoshi
Jan 17, 2010 09:54 AM
Blackzenki82
Nissan/Infiniti Tech
7
Jun 5, 2009 06:53 AM
Old Renegade
Feb 1, 2005 02:52 PM
CRXkid24
Jan 10, 2005 05:12 PM
Philly Blunt
Jan 28, 2004 02:53 PM
