idle is high help
Old Jan 27, 2004 | 02:07 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Default idle is high help
i have a b16 but it has a small ls throttle body so i put the b16 t/b on and it idles at like 1800 i have a small piece of the gasket missing though is that the only reason it would do that or could it be the map sensor
Old Jan 27, 2004 | 02:19 PM
99B16Si's Avatar
if the gasket is leaking you have a vacuum leak and it will cause the motor to idle high and irradic. get a new gasket for like 5 bucks and make sure u scrape all of the old one off both the maifold and TB first
Old Jan 27, 2004 | 02:22 PM
oh, well i held the ls t/b up to the b16 t/b wich i think is a b16 and there is like 2-4mm difference maybe i have a different t/b
Old Jan 27, 2004 | 02:25 PM
what size is the h22 t/b and what size is ls t/b
Old Jan 27, 2004 | 02:30 PM
redcrx187's Avatar
ALL MOTOR LS/VTEC
type r is the largest t body to fit a b series. h22 and newer b16 have the same size t boby. d series is smaller than b16.
Old Jan 27, 2004 | 02:58 PM
hey someone help me out how many mm are in a cm and how many cm are in an inch i swear to god my brain went completely dead and i cant fucking think of it i think i need to go back to first grade god dammit i am really pissed now
Old Jan 27, 2004 | 03:26 PM
hello?
