small turbo upgrade, need advice!?
Old Mar 13, 2007 | 10:41 AM
slowy's Avatar
13.04@104mph
Originally Posted by slowy
i have a 14b sitting in my garage $100. no shaft play.
ready to pick up whenever you are
100 for this 14b and 135 for the manifold. 235 for an upgrade isnt bad
Old Mar 13, 2007 | 10:50 AM
slowy's Avatar
13.04@104mph
im not sure if you have to change out the oil/coolant lines or not. the picture of them looks the same as the ones for the 2g 16g kit.
they sell a "kit" to redo the oil/coolant lines on a 2g but you dont 'have to' do them.
i've never seen a 13g on a car though
Old Mar 13, 2007 | 11:54 AM
edmel89's Avatar
That One Guy
im not 100% sure on the turbo, when i find out exactly wut turbo is in mine, ill let you know
Old Mar 13, 2007 | 12:00 PM
Tom N's Avatar
Non DSM.....DSM guy
If its a automatic it came with a 13g.
But that doesnt mean it wasnt changed out for a 14b and some point.
The turbo should say TDO4 or TDO5 on it.
TDO4 is a 13g.
If it is a automatic you will need to change the coolant and oil lines along with the exhaust manifold to use a 14b or 16g.
Tom
Old Mar 13, 2007 | 12:15 PM
edmel89's Avatar
That One Guy
TDO4 is a 13g.
ok this is my plan, tell me if its ok, i am going to get the TD05H Big 16g turbo, which comes with the oil and water lines install kit, aftermarket stainless steel headers, and a walbro 190lhp fuel pump (only if realy needed) im trying get the car running good, not trying too hook it up, also if i get a 14b, do i need the fuel pump?
Old Mar 13, 2007 | 05:51 PM
Tom N's Avatar
Non DSM.....DSM guy
Originally Posted by edmel89
ok this is my plan, tell me if its ok, i am going to get the TD05H Big 16g turbo, which comes with the oil and water lines install kit, aftermarket stainless steel headers, and a walbro 190lhp fuel pump (only if realy needed) im trying get the car running good, not trying too much to mod it out,
Yes its ok.
If you are going to put a 16g on the car definitely get the pump.
Also the automatic came with 390cc injectors not 450`s like the manual cars did.
I would get some 450`s for your car. Or 550`s if you find a good deal on some.
Tom
Old Mar 13, 2007 | 07:16 PM
  #17 (permalink)
Dario99gst's Avatar
Tu Papi Chulo
if you are short on cash you can just get the 16g and run low boost until you can afford to upgrade the injectors and fp.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Mar 13, 2007 | 07:22 PM
  #18 (permalink)
edmel89's Avatar
That One Guy
do you think i can just put on the 14b, no fuel pump would be needed? im mainly trying to get the car running first, you know, and i already have the 450cc injectors, had to get new ones so i just got those instead, would those injectors run good with a factory 14 set up? and no walbro fuel pump?
Old Mar 13, 2007 | 07:24 PM
  #19 (permalink)
Dario99gst's Avatar
Tu Papi Chulo
yes as long as you keep the boost at reasonable levels.
Just so you know, you only need to upgrade to a bigger fuel set up is if you plan on running more than factory boost.
basic hp equasion
air + fuel = horsepower
if you add more air you MUST add more fuel.
-Dario
Old Mar 14, 2007 | 03:15 AM
  #20 (permalink)
slowy's Avatar
13.04@104mph
you only need 1 header
if you want to turn up the boost, a fuel pump would be good to have
