Which turbo???
Old Oct 23, 2004 | 05:30 PM
  #21 (permalink)
Brandon's Avatar
Resident Dingo
Originally posted by Redlinegvr4
Dont upgrade til you max out your t25. Get your car breating good first (intake Exhaust) then do fuel (ie 550's or bigger depending on what you want) get all your gauges (boost, egt, A/F... etc) by then you should be maxing out the full power of your t25 then and only then you should upgrade your turbo. do it right dont just through on a bigger turbo and go. Also once you get the bigger turbo your gonna need a inter cooler and piping... etc so you have a long way to go before you should upgrade your turbo.
I've done all of that stuff that's why im looking to do a turbo upgrade now.
Old Oct 23, 2004 | 06:08 PM
  #22 (permalink)
Brandon's Avatar
Resident Dingo
Adding on to that post above, not totally correct, dont have the intercooler, that's coming in a couple weeks
Old Oct 23, 2004 | 06:09 PM
  #23 (permalink)
DeadSexY's Avatar
diballacully slow
you should learn a little more about your car before you upgrade anything. just my 2 cents
juan
Old Oct 23, 2004 | 10:54 PM
  #24 (permalink)
Brandon's Avatar
Resident Dingo
oh yea? thanx i'll keep that in mind
Old Oct 23, 2004 | 11:02 PM
  #25 (permalink)
NightRdnEclipse's Avatar
Ralfy
You interested in selling your t-25?
-Ralfy
http://www.myspace.com/ralfy4
Old Oct 23, 2004 | 11:08 PM
  #26 (permalink)
Brandon's Avatar
Resident Dingo
yea but it's got like 70k miles on it. I'm probly gonna do the swap in early december so i'll put u on my list and let u kno when i do it up.
u got a gs-t or looking to make it turbo?
Old Oct 24, 2004 | 11:43 AM
  #27 (permalink)
BoostLogik's Avatar
BoostAddict
a little misinformation....an FP Green is VERY streetable
When did I say that it wan't streetable at all. Maybe my wording was a little bad there. It's streetable, but still has a little more lag than other turbos out there.
Originally posted by 4drwhore
BOLOGNA!
You do not need stronger anything to run a FP green to it's full potential. The FP is the perfect turbo for a 6bolt motor in stock form. FP greens have gone 125mph with stock cams, which is about what people are seeing with the "all so awesome SCM61 turbos"(makes jerking motion). If you don't know what your doing then stick with a 16g or even if you do know what you are doing. A 50trim turbo is something not to mess with lightly. Note the video of the 2g gsx blowing its motor because he decided to throw on a fp green without suporting mods.
BTW stock 4g63 heads have seen 8500rpms with 272/272 cams in them plenty of times with no problems. No need to upgrade them unless your going 414s or over 8500rpms imo.
Last I checked, the FP Green is capable of 500HP. I think that around those ranges, it is a good idea to upgrade the connecting rods. I believe xgstxguyx is running a 7-Bolt motor, not a 6-bolt. People pushing 8,500 RPMs constantly are also usually the ones you see pulled over on the side of the road with smoke pouring out of the hood. I'm not saying that there aren't any 4G63s out there that have taken a beating and still lasted for a long time, but typically, they croak earlier than some ay expect. No doubt, our engines are strong as hell, but they are not bullet proof.
"Even through the darkest days, this fire burns, always"
Old Oct 24, 2004 | 11:54 AM
  #28 (permalink)
4g63's Avatar
Me thinks those rims need to go.....Sorry man but seriously......
Old Oct 24, 2004 | 12:00 PM
  #29 (permalink)
Brandon's Avatar
Resident Dingo
me thinks u can buy me new ones if u dont like them
Old Oct 24, 2004 | 12:22 PM
  #30 (permalink)
F4A22's Avatar
Old School
BURN!
