My 13b build blunders
Justin ill let you know whats up. Biggest thing is getting the new clutch installed and broke in. Hopefully i can tune it in time to run saturday night... we shall see...
Tampa Bay Rotary Owners Club Member # 4
PIT KREW
TEAM MEMBER
________________
Team Decep!
you never saw it coming
PIT KREW
TEAM MEMBER
________________
Team Decep!
Ran into a snag with my ignition setup. Seems i have to work around the trailing coil, and run tach feed from leading coil. That means i need to verify that the SAFC is reading r.p.m from leading (which it currently is NOT) as well as tach in the dash. Then i need to make sure the car still functions properly after getting away from the trailing coil. Should be a fun weekend worth of electrical drama.... While im at it im also going to fix my horn
PIT KREW
TEAM MEMBER
________________
Team Decep!
PIT KREW
TEAM MEMBER
________________
Team Decep!
No nothing wrong with what james wired up. I just ont like the factory tach pick up on the trailing coil. When i wire in the 2 step it will cut the power to the coils. which means that it will cut the r.p.m on the factory tach and the safc. which in turn means that while i have 2 step engaged... i have no tune.... which is not good while under boost. So im re wiring the safc r.p.m lead to the 6al box and the stock tach to. that way i dont have to worry about cutting power to the trailing and fucking everything up. Should be fun. Itll still be slow tho... till i give you the stock turbo and injectors and finally step up to what ive been prepping for.
PIT KREW
TEAM MEMBER
________________
Team Decep!
PIT KREW
TEAM MEMBER
________________
Team Decep!
Well the clutch and flywheel package finally showed up. It was nice of them to not give me a tracking order and then have a sign on delivery shipping policy to make sure someone was home. Good thing there were people at the shop or i wouldve had to go to waters again to get my parts...
PIT KREW
TEAM MEMBER
________________
Team Decep!
PIT KREW
TEAM MEMBER
________________
Team Decep!
sweet what kind of clutch did you get?
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
just a regular stage 3 clutch. Nothing fancy like last time. Did end up getting a lighter flywheel tho.. but only a lil lighter. Last one was 8.8 this one is 8.5. I have a feeling that the reason the last setup failed was cuz the great deal i got on a used flywheel wasnt the right flywheel. no dowel pins. Looked very shady when i figured out how everything attached, but i figured what the hell. if it goes ill just get another one. Well here i am, with another one. BTW, who wants an 8.8 pound flywheel for their FC?
PIT KREW
TEAM MEMBER
________________
Team Decep!
PIT KREW
TEAM MEMBER
________________
Team Decep!
sweet man should be fun. it sucks when clutches go out, such a pita to change
