Tuning for an rx7
Old Feb 24, 2005 | 11:52 AM
willjs7's Avatar
Default Tuning for an rx7
I just purchased a 93 rx7. i have quite a few mods on the stock turbos, and im getting an ECU as soon as possible. I was wondering what shops around tampa can tune the rx7, and which ones you guys would reccomend, also, does anyone know where i can get a decent deal on an Apex'i Power FC and commander, the cheapest i can find is 1,200$. thanks
Andrew-
www.autoliftplus.com
Your neighborhood do-it-yourself auto shop!
Old Feb 25, 2005 | 02:53 PM
Jap's Avatar
Jap
VTEC Out
Power FC = Garbage around here ...
Microtech LTX-8 is the way to go ... Scott at Mazsport in Largo can tune them , Carlos Gonzales in Orlando as well as the CFT guys ...
Power FC is ok to tune but its not a good option for hte money you spend . You can pick up a Microtech for 900 or so and then add a few hundred for tunning or get a base map and a wideband and tune it yourself ... If you have a decent idea about what your doing its not that hard ..
Hondata saves lives
Old Mar 1, 2005 | 05:07 AM
pianoprodigy's Avatar
I took the turbo out...
Scott at Mazsport does all of my work. He tunes both Microtech and Power FC, but I know he prefers Microtech. Give him a call at (727) 530-9960.
Ultimately, the ECU you choose should be based on your tuner's preference.
Actually, the LTX-8 has been superseded. The two choices for a two-rotor application are the LT8S and the LT10S. The LT10S has an on-board ignition amplifier and a few extra auxilliary inputs and outputs.
Current: LS1-powered 88 Mazda Rx-7 : Forged : Heads/Cam : Traction???
On Hold: H/C LS1-powered FD - Doing it Once, Doing it Right, Eventually...
Daily Driver: 2000 Mercedes SLK230 - 2900 lbs : 190 hp : Upgraded Audio
Past: 420 rwhp '02 H/C EB Z06 - 230 rwhp S/C FC - 230k mile '90 Toyota
Old Mar 11, 2005 | 05:45 PM
B20.eg's Avatar
haltec e6k. its older than the e6x ,so its cheeper(800), and works wonderfully.
Old Mar 22, 2005 | 08:55 AM
willjs7's Avatar
i wasnt looking to get picked apart for my choice in ecu. I just wanted to know where I can get a good tune around here.
Andrew-
Old Mar 23, 2005 | 08:37 AM
kpbjls1's Avatar
whats good?
if you want to come down to sarasota, we have tuned rx7s with the power fc's. PM me if your interested, my dad is the shop owner, and we have a lot of experience with engine management. and the power fc is a good choice for moderately modified cars, because it uses the stock harness.
P_Productions
Nissan/Infiniti Tech
19
May 11, 2004 09:45 PM
P_Productions
14
Feb 20, 2004 09:56 AM
Hybrid93Hatch
Apr 23, 2003 08:27 PM
Hybrid93Hatch
Apr 19, 2003 06:21 AM
squid00
Nov 5, 2002 05:39 AM
