someone please help me 95 accord starting problem
Old Jun 26, 2012 | 04:43 AM
jdmjim's Avatar
Default someone please help me 95 accord starting problem
OK so I replaced main relay and this morning went out and fuel pump just does kick on if I leave car in on position after few mins it works don't no what else to do going crazy trying to figure it out please help me
Old Jun 26, 2012 | 05:49 AM
jdmjim's Avatar
Ttt
Old Jun 26, 2012 | 07:20 AM
BoostedRacerDad's Avatar
Pops
Is check engine light "ON" and when it finally goes off pump then primes?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jun 26, 2012 | 08:00 AM
Pops
Look at the symptoms of bad ignition switch and match up problem. Do the test.
Starting Problems
JoKie TuNinG
StricKlyMT
727-510-6301
Old Jun 26, 2012 | 04:18 PM
jdmjim's Avatar
Thanks much gunna start in morning thanks bro
Old Jun 29, 2012 | 04:53 AM
sburtoncivic98's Avatar
check the ecu ground, and make sure the ecu is grounding out the signal to send power to the pump. Bad or corroted ecu grounds will cause all sorts of problems. Same thing happened on my EJ8. If every thing test good, i have a few more test that will help you out.
TR "Old Skool EF" Member #210
jdmjim
Feb 20, 2012 04:49 PM
CleanCe1Wagon
Oct 2, 2010 06:40 AM
quiksilvia
Nissan/Infiniti Tech
4
Sep 27, 2010 09:26 PM
*Ryan*
10
Jul 10, 2006 03:17 AM
CRXsi887
Aug 11, 2004 09:30 PM
