Please help fuel pump getting power wen it wants to
Old Dec 20, 2011 | 05:00 AM
Importracer13's Avatar
99CivicSi
Default Please help fuel pump getting power wen it wants to
ok i jus got my car up and runnin sunday everthin was fine then last night the fuel pump decides it wants to cut off on me... come to a stop wait a minute or 2 starts right back up get down the road samething happens again.. it happened about 4 times within a 3 mile radius... finally get it home start lookin thru wires then i realize the battery ground was loose.. i tighten it boom starts right up.... i already wired a switch into the lune and tested it that way first to see if the pump was bad.... well this mornin it starts right up with the swtich off start drivin about 4 miles pump cuts out flip the switch and then keep goin
idk wut it is main relay is new fuses are new pump is new its like the pump gets power wen it wants to...
does anybody have anyidea wut it could be?
I <3 BOOST
EM1 Crew Member #16
OVERDOSE CUSTOMS FROM BASIC MAINTENCE TO ENGINE SWAPS, CAR AUDIO , PAINT AND BODY
Honda,Toyota, Nissan,Ford,Chevy Dodge, Everything
14525 62nd streeet north Unit 3&4
Clearwater FL 33760
CALL OR TXT 727 465 8295
Iggy Azeala
Old Dec 20, 2011 | 07:51 AM
BoostedRacerDad's Avatar
Pops
Sounds like ignition switch/bad contacts
[HR][/HR]
How to replace the ignition switch or troubleshoot (Honda, Acura)
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Dec 20, 2011 | 09:26 PM
99CivicSi
see now its not getting anypower at all... but would that switch cause it to die while its running?
I <3 BOOST
EM1 Crew Member #16
Clearwater FL 33760
Iggy Azeala
Old Dec 21, 2011 | 02:23 AM
Pops
You could be losing voltage on IG1 on this diagram.
How the Main Relay works
Are you running a 255lph walbro or bigger? If Yes you might have to install a relay with 10 gauge wire as I bet your main relay is getting Hot. This could be THE problem.
Pm for how to wire in a additional relay.
JoKie TuNinG
StricKlyMT
727-510-6301
bigpudge
Jul 4, 2010 12:58 PM
eksilver1
Oct 3, 2008 04:22 AM
topher469
Apr 7, 2006 07:31 PM
steve
Nissan/Infiniti Tech
18
Sep 6, 2005 07:16 PM
