no power to my fuel pump
Old Jun 29, 2010 | 08:34 PM
bigpudge's Avatar
Default no power to my fuel pump
alright tr i have a 1988 ef and i just got my walboro fuel pump tested it out and everything to make sure it work's and everything so i installed it put in my fuel tank and everything i even doubled check the plugs and everything and when i turn the key i dont here fuel pump or get any fuel 2 my motor so i get the positive wire of the fuel pump and splice it and ran a wire to the battery and was working fine but i really wanna 2 work of the key so anybody was too help that will be awesome
will rep for any little info i can get thanx
TR "Old Skool EF" Member #190
Old Jun 29, 2010 | 09:24 PM
bigpudge's Avatar
Old Jun 29, 2010 | 09:40 PM
Red2GDSM's Avatar
In the making...
check the relay??
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Jun 29, 2010 | 10:27 PM
bigpudge's Avatar
its good i dont think its the relay
Old Jun 30, 2010 | 03:04 AM
chi town brat's Avatar
! Ne shab'rud'ni !
question: why did you buy the walboro in the first place? was it because you thought the stock one had went bad?
i'm just trying to see the history to see if that history relates to the current issue.
Old Jun 30, 2010 | 08:19 AM
bigpudge's Avatar
i bought the walboro cuz i thought the old one went bad and when i took it out and tested and it still worked but not so good. it wasn't even blowing that good anymore. on top of all that it was all rusty looking. i also bought the walboro cause i'am gonna put my car on some spray in the future so i thought i mighty-es will get this out the way
Old Jun 30, 2010 | 12:12 PM
! Ne shab'rud'ni !
okay. that helps.
my suggestion would then be to find the wiring diagram for your car or if you already have it look to see where everything is going. something along the way is not happy.
maybe a ground?
i am not good at wiring but i am trying to figure it out and my friend is teaching me to start at the beginning then work my way back to see where everything leads to and connects with.
Old Jun 30, 2010 | 01:09 PM
bigpudge's Avatar
no i dont think is a ground i only took the positive wire of the fuel pump 2 the battery and works just find i thinking its something behind the fuse box under the dash
Old Jun 30, 2010 | 04:20 PM
FrodoGT's Avatar
Found the Vtec switch.
How about the main relay? the #14 fuse? there really is not very much TO the circuit that kicks the fuel pump.
TR Old Skool EF Crew #24
Old Jun 30, 2010 | 04:47 PM
Thatguysstuff's Avatar
Hey its that guy!!
Sounds like main relay..
The Efs are prone for problems with them.. Just bought a broken down CRX.. checked the relay and fixed it and drove it home.. Owner didnt have the car running for 1yr...
here is a pick of the location if you dont know where it is..
