no power to fuel pump help
ok so the pump is getting no power
swaped pumps still nothing
what the hell is going on
how it happaned
drove car took off power fan's put on clutch fan start car no fuel
how it happaned
Maybe this is a dumb question, but I would still like a response - Why would you want to get rid of your electric fans to put on a clutch fan. I believe that the electric fans are better in every way.
and ask this some where else thanks
i need my car working does anyone have a fuel pump assembly i can have ?
Have you tested the fuel pump outside of the car to make sure it works? I would start with a test light on the fuel pump wires in the tank and also check the fuse in the fuse box. I only add the fusebox comment, because it commonly gets overlooked by people when they get frustrated. Good luck
i am having a similar problem,...i took my fuel pump out of my CRX and wired it str8 to my battery and it worked, so i got it back in there and i wired it str8 to my fuse box. i havent tryed to start it yet cause i have been busy,....but it does pump fuel,...
