i need help my ls trany is stuck wont move!!!help!!
It was a full swap all together in one piece...I. took it apart for better fittin in my back seat and oil cam out the tranny and wen I went to drop the swap in I drain all fluids out.^
http://i36.tinypic.com/2jabubl.jpg "TR Old Skool EF" Member #219 JDMASFUCK
DD.miata fastback top
today I changed my tranny and I never had a throwout barin in my old trand and thr spring inside was streched out.so I replaced everything and my driverside wheel moves a lil but its hard.and the other side don't at all...could it be my wheelbering or sumthing???help me out tr!!
post more info man, we have to have very detailed information to help you. Is your car running with your car in 1st gear with the clutch pressed in? or is it off and not moving?
The swap is in the car but it does not turn on cus I don't have the harness on cus its gotta b wired by neal...after I changed the tranny I put it in 1st and tryd to spin the wheels and It was hard then I shifted to nuteral and the driverside wheel spins but kinda hard and the pass side don't really move unless a lot of pressure is applyd on it.so idk wat can it b I kno its not the tranny or the engine cus it was spining b4 I conected the halfshaft to the axle on the driverside and so did the passengerside too..I hope this info helps to figure out wth is wrong with my car now..
^+1 If you have Neal already helping you, you don't need anyone else.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Whoa I never knew he works on hondas other than wires.....and I'm tryn to get this car ready to run so wen neal come to wire it up it will b completely ready to run and I'm tryn to have this car runin ok by sat wich is my bday and sunshine dragsrtip
