i need help my ls trany is stuck wont move!!!help!!
I'm gonna try today ^^and na it has no fluid that can be my problem..were do I fill in the oil at?the screw were I drain from??^
http://i36.tinypic.com/2jabubl.jpg "TR Old Skool EF" Member #219 JDMASFUCK
DD.miata fastback top
Alright I turnd the crank and it dint move and I opend the tranny drain bolt and nothing came out...I need help asap tr
the bolt that you unscrewed to check the fluid is where you add the fluid as well, get a slim funnel and a few feet of hose (that you know will fit in the drain hole) and add fluid. 10w-30 should be fine but double check first. this still may not solve your problem if you ran your tranny with no fluid you tranny may not be functional anymore.
Damn alright but the tranny spind freely wen it was out of the car so idk now how bout the center shaft in the trany does that need to be in a sertin way??
Help tr
It had oil in it wen I got the swap I never got to turn the car on or nothing...I don't even kno were to put the fluid in threw..and I already have a new tranny but I still wanna kno wat can be wrong with the old one..
Idk the dude that sold me the swap said the tranny was good and I never drove it b4...I seen the dude drivin it to the races and that's all and that was once
