No vtec, what could be the symptoms?
Old Jan 20, 2011 | 03:07 PM
  #21 (permalink)
Brandon H.'s Avatar
The tach worked fine before taking it apart, didn't touch the wiring for it. It's connected straight to the dizzy wire. It actualy worked first time after getting it back together, and not now, with the same symptoms with the car was giving me.
No CEL on ACC. Never seen the light before
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Jan 20, 2011 | 05:05 PM
  #22 (permalink)
CRXkid24's Avatar
uh oh
if you dont see the check light when the key is turned to acc it aint working at all. it should come on and turn off.
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Jan 20, 2011 | 05:21 PM
  #23 (permalink)
Brandon H.'s Avatar
Guess im going to have to figure out how to pull the cluster
If its not one thing its another.....
Would there still be a code??
1999 Honda Civic Si
TR em1 crew #43
Old Jan 21, 2011 | 05:17 AM
  #24 (permalink)
Alswizzo's Avatar
The Underdog!
If something its not right you will have a code, this might be preventing Vtec from activating.
1. Fix your bulb and see if it has a check engine light
2. If your desperate head To Autozone and tell them to scan your car for codes
Old Jan 22, 2011 | 09:01 AM
  #25 (permalink)
Brandon H.'s Avatar
Went to Autozone to have the code pulled. Only 2 codes
P0117
P0113
After lookins that code is IAT, which is probably that sensor plug that is unpluged. Sounds to me that it went to the stock intake, but since I have a "hot air intake", its gone. Its been gone since I have had the car so I know its not the problem.
Is there any way to temperarily ground the ECU? I need to find out if its a ground or posibly omething in the Dizzy. I did notice on my way to Autozone my aftermarket tach would freak out.
1999 Honda Civic Si
TR em1 crew #43
Old Jan 22, 2011 | 08:57 PM
  #26 (permalink)
Brandon H.'s Avatar
Anyone?
1999 Honda Civic Si
TR em1 crew #43
Old Jan 23, 2011 | 08:22 AM
  #27 (permalink)
BoostedRacerDad's Avatar
Pops
P0117 is coolant temp sensor which needs to work for Vtec
There are actually three temp sensors. The 2-wire temp switch for the fan on thermostat housing, the 1-wire temp sending unit for the dash gauge under the distributor, and the 3-wire temp sensor for the ECU forward of the sending unit under the distributor. The last sensor is related to CEL code P0117. You might have a bad sensor but since you just pulled the head and all was fine before maybe you plugged the connectors in wrong??
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jan 26, 2011 | 06:54 PM
  #28 (permalink)
Brandon H.'s Avatar
Fixxed it, I replaced the sensor with one I had laying around, got a new dizzy from a member on here B18B OBD2, but I swapped intrnals into my B16 housing, then had no spark at all. Ended up with a blown fuse under the dash.
Starts right up, and runs better then before I broke it. Gotta love Honda's, just wish my dirtbike wasn't so finicky
I will be getting in touch with a few of yall later this week, I promised to give those who kept up with my threads and help me get the car running a few bucks... sorta to say thanks for the help. I will PM yall later.
1999 Honda Civic Si
TR em1 crew #43
