No vtec, what could be the symptoms?
Old Jan 20, 2011 | 05:22 AM
Alswizzo's Avatar
The Underdog!
Check your grounds, and make sure you didn't mix up the tps plug with the map sensor?
Old Jan 20, 2011 | 06:53 AM
Brandon H.'s Avatar
Do those sensors have the same plugs?
I know the ground by the tranny is there, and the ground strap on the valve cover.
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Jan 20, 2011 | 07:59 AM
Alswizzo's Avatar
The Underdog!
Yeah, they do.
That tranny ground is very important, make sure its not corroded and clean it and the chassis if you have to. This ground has gave me serious problems before.
Also check the ground on the thermostat, That thing grounds the ECU.
Old Jan 20, 2011 | 08:41 AM
Jason.'s Avatar
As stated above, check grounds for sure.
Also, if the tach was working, and isn't anymore, that is ran to the distributer, check the dist. cap, rotor, etc. Could be a coil aswell.
Ton's of things it could be, also take the vtec solenoid apart and clean the screen out, if the oil builds up in there and can't get through like it use to, it will cause problems.
And if all else fails, I like blue Si's, so PM me a price. HAHA
2011 Kia Optima SX Premium/Touring package
Old Jan 20, 2011 | 08:51 AM
BoostedRacerDad's Avatar
Pops
What codes are you throwing?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jan 20, 2011 | 12:03 PM
Brandon H.'s Avatar
The solenoid has been cleaned.
I'm sure the map/tps is correct but I will double check. It was doing this before I tore it all down as well, just woulnt run, where as now it clears out and runs.
The factory tach works, the aftermarket one shows movement while cranking and nothing while running.
Can I temporarily ground the it with thick amp wire? Like a wire from the head to the battery just to test?
Also no check engine light. Would autozone be able to pull the code?
1999 Honda Civic Si
TR em1 crew #43
Old Jan 20, 2011 | 12:11 PM
  #17 (permalink)
mox92's Avatar
Ek
na cause the computer has to throw a code for the code scanner to pick up
Old Jan 20, 2011 | 01:13 PM
  #18 (permalink)
Brandon H.'s Avatar
Yes but what if the light was bad like someone else had posted? Or is it posible the previous owner it turned off (if it's posible)...... Idk I'm use to carbs not ECU's
1999 Honda Civic Si
TR em1 crew #43
Old Jan 20, 2011 | 01:19 PM
  #19 (permalink)
89crxsir's Avatar
Does the tach work?? It could be the igniter in the dizzy is going south...
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Jan 20, 2011 | 01:27 PM
  #20 (permalink)
Alswizzo's Avatar
The Underdog!
if you want to know if the CEL works its easy dude, when you turn the key to ACC power you should see it light up, and then if it checks out fine the light turns right off. Check it out.
