Suspension expert needed ASAP!
Old May 8, 2010 | 10:59 AM
  #31 (permalink)
DC2_BoostKING's Avatar
CRAWFORD BUILT
i had the strut positioned so i could remove it by removing the rear sway bar bolt and the camber arm. it gave me plenty of room.
and i have a ball joint puller. the nut came off after putting the 3/4" breaker bar on it and a 4' extension. the bolt must be threaded into the lower part of the strut though. the 15lbs sledge should have knocked it out if anything. even if for some reason it was cross threaded it still should have came off.
when i put the 3/4" bar and the 6' extension on the bolt it just shredded the socket.
idk i'm out of ideas...
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old May 8, 2010 | 11:11 AM
  #32 (permalink)
CEMAYHALL's Avatar
www.CEMayhall.com
Let me get this straight... You broke the welded nut on the back of the shock free but you can't get the bolt out?
Old May 8, 2010 | 11:49 AM
  #33 (permalink)
FoxHondaRider's Avatar
Registered Hater
Bring out the sawzall and just go wild on your car lmao cut that shit out fuck stuck bolts just cut around them like the kid who couldnt get his lugnuts off so he cut the spokes off the wheel
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old May 8, 2010 | 11:58 AM
  #34 (permalink)
Brandon H.'s Avatar
Originally Posted by FoxHondaRider
....just cut around them like the kid who couldnt get his lugnuts off so he cut the spokes off the wheel
Your kidding right??
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old May 8, 2010 | 01:29 PM
  #35 (permalink)
zhillz's Avatar
Porno Music Producer
So, Dont buy a VW - Honda-Tech
Old May 8, 2010 | 06:02 PM
  #36 (permalink)
This should not be as much trouble as you are going through.
A spring compressor should not be put on a spring unless the shock/spring is already removed from the car. Don't ever unscrew the top center bolt/nut of a shock with it still on the car.
We are giving suggestions based on what we think the problem is.
I would like to actually look at it. There is something that we are missing, here.
What part of town are you in?-Bob
Old May 9, 2010 | 05:08 AM
  #37 (permalink)
CRAWFORD BUILT
Gainesville, CEMAYHALL already offered to come over and help. thanx again man for the info! me and him discussed what the problem is and i'm just going to wait until i get the kyb's and the aftermarket lower control arms and assembly everything outside the car and remove the factory LCA with the strut still attached from the car. i have even spoke too several mechanics about this and it's left them scratching there heads too.
what CEMAYHALL and i believe is happening is that the bolt being as old as it is, is fused into the bushing. i would have to remove the whole LCA and take it too my shop to press it out.
CRAWFORD BUILT
DC Crew Member #23
Old May 9, 2010 | 08:03 AM
  #38 (permalink)
Keep us posted so we will all know the solution. Thanks.-Bob
