Engine Problem
Old May 31, 2002 | 01:21 PM
95c1v1cs1's Avatar
I got the CEL off, but my rpms are still going all over the place. It messes up my acceleration a bit, do you guys have any idea what that is caused from? I was thinking a bad distributor maybe.
Old Jun 1, 2002 | 04:35 AM
95c1v1cs1's Avatar
It seems to flutter off and on. Sometimes it is when my car is just sitting there. When i hit on the gas sometimes the rpm changes will make my car bog out. Some times it will turn my car off. But that is usually when i just start it up. I get no codes right now. I need your help if you guys got any ideas.
Old Jun 1, 2002 | 11:49 AM
95c1v1cs1's Avatar
right when i hit about 4k rpm everything seems to go.
I can't drive it past 4k or it will basically slow down. it is bogging out or something. It does that all the time now.
Do you think it is the distributor or the EVAP sensor?
Pollo- Which one is the IACV. is that the one on the back of the throttle body?
Old Jun 1, 2002 | 02:28 PM
RONIN's Avatar
Tetris on a stick
what swap did you do? what ecu are you using, what year?
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Jun 1, 2002 | 03:33 PM
  #17 (permalink)
Adam12's Avatar
Nohatch2000
check all your grounds especally the one on the tranny and the one on the harness by the thermostat they will cause the motor to do some funny shit
-Adam
Old Jun 1, 2002 | 08:47 PM
  #18 (permalink)
95c1v1cs1's Avatar
Originally posted by "POLLO"
I doubt evap has anything to do with it. The IACV is the sensor that has 2 hoses right behind the intake manifold....... the screen on those usually gets dirty and causes it to idle all weird......
That must be it. I had to rig it up so that the vacumm line would go iinto it. thanks for your help. Sometimes it runs good and sometimes it runs like absolute sh*t. I thought that sensor was the EVAP sensor, that is why i was asking about that. Anyone got one for sale?????
Old Jun 5, 2002 | 12:52 PM
  #20 (permalink)
Adam12's Avatar
Nohatch2000
lemme know what you need
-Adam
