Engine Problem
Old May 29, 2002 | 07:30 PM
95c1v1cs1's Avatar
Well i just dropped an engine in my car yesterday and finally got it to turn over today. Anyway I drove good for like 4 hrs and then i was driving the car and it suddenly just turns off. The check engine light comes on and my car will not start up. To make a long story short i started hiting the starter and started up again and i drove it home. On the way home the CEL was on the whole time and the rpms where going all over the place but the car was reving any different. I get no codes when the car is off. The check engine light only comes on when i start the car.
Old May 29, 2002 | 08:02 PM
Bill's Avatar
Livin' in Seattle
step one...pull the code
step two...tell us the code
Old May 29, 2002 | 08:05 PM
therainforest's Avatar
well turn you cars auxs on and and then check for the code or turn the car on. then reqad it and tell us.
Old May 29, 2002 | 08:35 PM
95c1v1cs1's Avatar
I get no code when the aux is on. When i turn the car on it is just on. no blicks or anything. Just on. Is there a way to get it to give me a code??
Old May 30, 2002 | 03:02 AM
b18 ctr's Avatar
you need to jump the plug with a wire down by your ecu for the light to flash
i have a slow civic
Old May 30, 2002 | 03:09 AM
there is a green plug on the passenger side next to the ecu that has 2 holes you have to jump it (make a u out off a paper clip and have it in both holes) then you can run the aux and the code will blink.
Old May 30, 2002 | 11:54 AM
95c1v1cs1's Avatar
thanks for the help. It blinks twice slowly and then has a break and blinks 5 more times. they are all the same speed except for the last blink on the 5 spread. It ends really quick compared to the rest.I looked up the code and didnt see anything. Im not really sure how to read it but i thought it was 25.
Old May 30, 2002 | 05:38 PM
2qk4u's Avatar
it could be showing you 2 codes.
2 and 5
i dont know though
Old May 31, 2002 | 03:17 AM
95c1v1cs1's Avatar
Thanks!
