OMG-my sh*t still wont fire
Old Feb 17, 2010 | 10:40 AM
  #61 (permalink)
rangcrx's Avatar
engine building &best
^There is something wron with that motor I have never in my time seen one so hard to spin ever,and it made it feel like it was seezed up,plus I have never seen so much sealent on ever thing that's strange I mean it was a lot,not sure why when all the seals were new
i love AUTOZONE
Old Feb 19, 2010 | 07:17 PM
  #62 (permalink)
mogo21's Avatar
I didnt assemble the entire car / i assembled the block and helped him bolt it up in the car then i went home . The only sealant i used was rtv gray on the oil pump and pan gasket / everything else has nothing to do with me i did the job i was requested to do ,(ASSEMBLE A SHORTBLOCK) whether the motor was clearanced and plastigauged prior to my assembly im not sure, i assumed everything was done at the machine shop thats what i was told , the motor is very tight thats the bottom line ( ive built countless amounts of motors from Chevy"s to big block fords < all still running to this day . so gather your intel properly before pointing fingers / No offense Rang but your are not the only person on the planet that builds hondas < sorry
Old Feb 22, 2010 | 07:03 PM
  #63 (permalink)
Tampa's_Slow_EG6's Avatar
Living in Black & White..
sooo did it run?
Old Feb 22, 2010 | 10:54 PM
  #64 (permalink)
sprjit22's Avatar
Rick James bitch
Well I can say that Rang is good at what he does. Now as far as not plastiguageing the bearing clearances that is just foolish. Part of the builders job is to find any issues their might be. i.e. inproper rod cap on a rod mitch matched mains etc etc.....
When YOU put a motor together YOU should check everything because it is YOUR name on it. Unless you request it most of them are not going to check your rods crank etc etc. If you tell them to bore the block then thats what they do not check all your clearances etc etc.
If you want me to build the motor then bring it to me and we can work something out. you have my number. Ill stand behind it 100% and I will know what all your clearances are not assume the machine shop checked it.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Feb 23, 2010 | 02:55 AM
  #65 (permalink)
JoKiE crx4294's Avatar
popeye built!
Where the rings clocked when put on the pistons? You can't put them on facing the same way, or it wont hold compression.
Can't spell strength without tren
AAS...It's whats for dinner
Old Feb 23, 2010 | 04:10 AM
  #66 (permalink)
rangcrx's Avatar
engine building &amp;amp;amp;best
Well I don't know if his going to answer not to go behind his back but yes there were motor problems and over tightening..but good news is lopezchris took his own motor apart put in a old set of rings fixed his backwackwards thrustwasher and his motor starts fine now.from what he told me
i love AUTOZONE
Old Feb 23, 2010 | 06:44 AM
  #67 (permalink)
HonkeyDong's Avatar
Every dog has his day.
building motors without measuring clearances FTL...
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Feb 23, 2010 | 08:36 AM
  #68 (permalink)
integra's Avatar
90% grind 10% sleep
exactly
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Feb 23, 2010 | 09:35 AM
  #69 (permalink)
sprjit22's Avatar
Rick James bitch
Dont hate the guy is a pro lol
T & C Racing
FT Crew Mascot lol
Old Feb 23, 2010 | 04:57 PM
  #70 (permalink)
mogo21's Avatar
Not hating just dont appreciate the shit talking < the motor ran fine in the beggining he put 500 miles on it without issue then it started smoking , not my fault by any means everything was done properly , i put together what parts he gave me . Nothing was backwards at all , i stand behind my work 100% also thats why i made 3 or 4 trips to his house to help him figure out the issue .Anyway , im just glad he's got his car running + 1 for chris
