clutch CHATTER
Old Nov 5, 2009 | 04:55 AM
  #31 (permalink)
DC2_BoostKING's Avatar
CRAWFORD BUILT
^^^ doing that today. lost all my fluid 2 days ago for no reason, i walked to my car (sitting at a friends apartment) and when i took off noticed that it only engaged when the pedal was all the way to the floor and it would pop if i released it to quickly. i lazily re-bleed it yesterday just so i could drive it (plus i have the flu, so i wasn't thinking straight) and now it engages all they way at the top >:/ so i'm going to do it right today.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Nov 5, 2009 | 09:37 PM
  #32 (permalink)
StrictlyBusiness's Avatar
Mr. Stealyogirl
Sounds like the flywheel and or pressure plate have heat spots.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Nov 5, 2009 | 09:42 PM
  #33 (permalink)
AllShowNoGo's Avatar
or just a POS clutch?
Old Nov 5, 2009 | 09:45 PM
  #34 (permalink)
Mr. Stealyogirl
Or that
All I know is when I put my clutch in I had my flywheel and pressure plate resurfaced and I had almost 0 chatter. Now, my flywheel and pressure plate are covered in heat spots and clutch chatters terrible.
www.jdmmindz.com
Old Nov 5, 2009 | 09:52 PM
  #35 (permalink)
you can pick up a nice clutch for a decent price, Exedy stage 1 isnt to much and feels real nice.
Old Nov 6, 2009 | 12:10 AM
  #36 (permalink)
Nandosol's Avatar
Garage Slut
yea sounds like bad clutch/pressure plate
Youre not gonna know until you take it apart. If your clutch is not engaging correctly because of leaking/air in hydraulic lines you will eventually have to fix/replace the clutch/tranny
Old Nov 7, 2009 | 09:49 AM
  #37 (permalink)
94lsteg's Avatar
BOOST IS BETTER!
i mean if it was that it wasn't engaging, wouldn't it be slipping??? That's not the case, it grabs HARD......
Old Nov 7, 2009 | 11:12 AM
  #38 (permalink)
Mr. Stealyogirl
You can get a clutch disc for cheap, but thats only if he wants the disc. I got my ClutchNet 4 puck for like $110. Im sure BayCity clutch has something he can use.
I dont think soemthing is wrong like functional, I think they have hot spots. Thats just my opinion
However, a friend with a 240 has been having this problem, so we pulled the tranny and his flywheel bolts were coming out and were finger loose
www.jdmmindz.com
Old Nov 7, 2009 | 01:37 PM
  #39 (permalink)
94lsteg's Avatar
BOOST IS BETTER!
Yea, i would be afraid of that...but i've taken at least 6 trips from tampa to gainesville and back, and it doesn't seem to be getting any worse. Same noise as when i got it.
