looking to upgrade
Old Aug 16, 2009 | 03:03 AM
  #31 (permalink)
teamjdm239's Avatar
6speed rhd integra!
Originally Posted by single_slam94
thanks for the help.. haha but i dont get half of what you just said. whats the n/a and weakest sleeves??
n/a stands for naturally aspirated:all motor,no power adders(forced induction , or nitrous )
and when i said weak sleeves , i meant the cylinder walls. cylinder sleeves are in the block, and are where the piston goes up and down.
K*Squad
Uk spec 99 rhd dc2 integra
MugenPower
Old Aug 16, 2009 | 05:34 AM
  #32 (permalink)
single_slam94's Avatar
im a girl. so?
thanks haha
Old Aug 16, 2009 | 05:35 AM
  #33 (permalink)
im a girl. so?
cant weak sleeves eventually cause damage?
Old Aug 16, 2009 | 06:03 AM
  #34 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
Yes when they crack due to the built up pressure in the cylinder they will trash your block.
Old Aug 16, 2009 | 06:04 AM
  #35 (permalink)
teamjdm239's Avatar
6speed rhd integra!
+1
K*Squad
MugenPower
Old Aug 16, 2009 | 06:44 AM
  #36 (permalink)
im a girl. so?
yeah so i'll probably stick to a b18 engine. upgrade some of the other parts too.
Old Aug 16, 2009 | 06:59 AM
  #37 (permalink)
custom240sx's Avatar
DC Crew Member #1
Don't shy away from the b20...the sleeves are NOT as weak as people think. I've seen b20vtecs on 10-15psi of boost with stock sleeves running just fine. Mine is boosted to 7psi and my friends to 8.5psi...mine has seen redline (of 7200) for close to 2 years now everyday and has NO issues.
Old Aug 16, 2009 | 07:07 AM
  #38 (permalink)
im a girl. so?
i most likely wont race mine alot. so then.. it should last a while and be just fine correct? ive got the stock d16z6 in my car now and its going on 16 years still working perfectly. only 161000 miles on the car. im looking for something with more power and speed but just as reliable.
Old Aug 16, 2009 | 01:31 PM
  #39 (permalink)
! Ne shab'rud'ni !
since you are looking for a good street set up and not interested in racing too much then i would say go for a build/swap that gives you a good amount of low end torque and good mid range.
The LS and B20 are very good for this. And as NAs they are ones that are low maintenance and will last.
On the B20 a little head work, some cams, the right transmission, and a good tune and you'll more than likely be when you step into the gas.
Old Aug 16, 2009 | 06:11 PM
  #40 (permalink)
im a girl. so?
thanks.. what type of transmission would it need?
