v-tec head swap
Originally posted by "Someone"
Originally posted by hellad15
you need a Honda vtec cooler and blowoff switch if your gonna run
the p-28 however if you do the 1/2 switchover you just need the
cambercrank of the 99-00 vtecs..good luck
Jarule-Damn hes got enough vtec cooler in there to blow himselfup and that crazy fools runnin a up blow off switch and a cambercrank.
Guest
Posts: n/a
damn..if your car is topping out at 85..you need more than just
the 2vte-c coolers..you need the big ones and camber crank..you
need the p.s.i. depressurizer valve debigulator and Honda Oem
emancipation proclimation..for discrimination agaist torque..that
should boost you up to about 125
Maybe you dont understand that when your name is beside something that you are saying what is beside your name like the script from a movie. Let me give you an example
93sircivic-I have a 93 si
hellad15-I have a cambercrank
93sircivic-cambercranks are for ricers
hellad15-no their not it gave me 25 hp plus the cambercrank sticker added 10 hp more.
93sircivic-you riceboy
you guys are too much. Hey Hellad dont listen to these guys you just keep on being a stupid ass because you definitely supplied me with the comedy relief that I needed tonight. I just hope j99jm gets to see this when he is ripped.
ps hook me up with one of those emancipation proclamations. I need to free the negros that are enslaved in my rear secondary injector stabilizer bracket valves. thanks
HMMMM.... Whats more fun??? Smoking a quarter in a car or smoking a car in the 1/4???
Guest
Posts: n/a
damn hellad15 are you one of those no school gypsie drop outs? i hate you freakin gypsies.evrywhere i damn go you gypsies are everywhere...your uncle pisses me offdamn gypsie cursed me.i swear you can understand gypsies fo shiet! listen to me ole gypsie boy...if i see you i will..repeat will reverse that curse on to you.........you will become thinner!
