v-tec head swap
I am doing a head swap on a d16a block and a 96 sohc v-tec head. It is coming with (gaskets dist int/man plugs wires head bolts tb sensors valvetrain ) i already know I need a v-tec header what else do i need to make it run without any probs. Also can anybody help me put the head on pretty cheap.
SHIFT_automagically
SHIFT_automagically
what car are you putting it in to if a crx with is what im guessing since you said d16a block you need a rpm switch. if a eg or ek than get a p28 ecu. the parts you need are a 96+ timming belt and head gasket. if you need any more help pm me.
that's president hussein obama to you :gordy:
Guest
Posts: n/a
Guest
Posts: n/a
Originally posted by hellad15
you need a Honda vtec cooler and blowoff switch if your gonna run
the p-28 however if you do the 1/2 switchover you just need the
cambercrank of the 99-00 vtecs..good luck
Guest
Posts: n/a
naw man..im straight.
i doo have a Q though..my friend said my v-t-e-c wasnt working
and i looked at my wiring and saw i had no V-te-c solenoid then
i looked at my stickers on the back of my car and it said
dx..then im like oh...that fucker who i bought the car from
ripped me off and didnt give me my V-T-ec..that bastard however
i found a vT;ec and sprayed it on...so its all good now
