Really odd dyno numbers..Discussion...
Old May 10, 2009 | 09:16 PM
Paulino's Avatar
Not harsh, just truthful
Join the fun Danny boy!
Old May 10, 2009 | 09:17 PM
Ls_[eg]hatch's Avatar
mowchowbrowncow
its cause its still a 1.6 bottom end...seems right to me.
b16s dont make 165wheel stock more like crank lol
Old May 10, 2009 | 09:19 PM
mighty_mouse12's Avatar
MUSTANG NAZI!
There Might Be Something Seriously Wrong With His Bottom End But Those Numbers Are Not Like Stock.
OLD SCHOOL EF CREW MEMBER #100
Old May 10, 2009 | 09:21 PM
Paulino's Avatar
Stock B16's with higher compression than stock should make more power/torque than stock. It doesn't make sense.
Old May 10, 2009 | 09:22 PM
Drivermod03's Avatar
190? No way. I helped a friend build a high compression type-r with a laundry list of good mods and it made 195.
Paulino's Avatar
+2
  #17 (permalink)
mowchowbrowncow
stock b16 will put down like 135-140 wheel n like 111fptq so 20whp from a set of cams is pretty good
Old May 10, 2009 | 09:23 PM
  #18 (permalink)
Paulino's Avatar
I guess Vega just hyped the guy up.
Old May 10, 2009 | 09:24 PM
  #19 (permalink)
sleepinsol's Avatar
starting over
I would tend to say that tose cams are bleeding off too much compression from that tiny little motor. those pistons put it at around 10.5:1 ratio with that head. those cams are reletively large on the exhaust side, and are designed for minimal crossover road race profiles. down low, the b16 doesnt move a ton of air to begin with, and at the compression it has the large primary lobes could possibly be too much for that motor to handle. once it gets into the high end on the graph the power seems to build nicely and carry very far. I would think some ctr pistions in there, and possibly some head work may help that motor a lot! thats just my theory tho.
  #20 (permalink)
Paulino's Avatar
You still don't get it. He made 98 ft-lbs. That's retarded.
