poormans type R
Old Dec 11, 2001 | 04:23 AM
86crxsi's Avatar
shit anymore b16s just layin around in da shed?
Old Dec 11, 2001 | 06:32 AM
CoLJeW's Avatar
LoL.. yeah sounded good huh.. no other motors. just had a head off my old motor...
I am actually going to go turbo by summer time. I was told by people that the geometery of the b16 head was closer to the type r head then the GSR and it would be worth switching. keep advice coming I wanna know before I do the switch. This motor is actually just getting droped into the car. what would the wiring differnces be if I put the whole GSR in my EF I already had a b16 thats another reason why they talked me into it.. said my wiring wouldnt have to change.
Old Dec 11, 2001 | 06:38 AM
CoLJeW's Avatar
also keep in mind that I have both heads already so let me know of any switching of parts that someone knows works.. do the GSR valves fit in the B16? Combonations of different cams etc..
Old Dec 11, 2001 | 07:46 AM
webdog's Avatar
Originally posted by "Someone"
I had this swap on my last GSR becuz I blew my GSR head. Not recommended if youre not going high compression pistons becuz like they said u will lose compression (unless of course ure planning on going turbo but in that case id just use an LS motor). On my swap I used B16 pistons in my GSR block but for even higher compression CTR pistons and CTR cams would make a wicked motor. But if ure going to do all that you might as well get the head ported. So I guess the smartest (cheapest) route would be to sell the head and get a Skunk manifold. Unless you dont mind being carless for a month or so.
Old Dec 11, 2001 | 11:18 AM
CoLJeW's Avatar
ok so I think I might stay with the GSR head then and sell the b16 head. Now.. what are the differences in wiring.. I have had a JDM b16 in my 89 civic but am switching to the GSR what changes in wiring will I need to make.. will my engine wiring harness hook up to everything if not what do I need to change or add..
hybridEG
Mar 8, 2001 04:30 PM
sihatch
Feb 3, 2001 09:19 AM
hybridEG
Jan 30, 2001 06:23 AM
