Springs
Originally posted by "Someone"
Originally posted by Bill
I agree. It sounds to me like youre getting springs more for cosmetics than performance so Id just go with a set of H&R sport springs or some something similar from Eibach.
Originally Posted by Someone
Originally posted by revhard
Do I want a progressive rate spring? Also just how bad are the cheapo $99 springs? Im sure just about anyting will be better than cut springs but how bad are they? Thanks for the scoop john!
Sorry last time with the same stupid question Other than $180 whats the difference between this speedpeople.com coilover and the GC coilover? With a coilover as you lower the car more youll get stiffer spring rates so in reality you should be able to get the desired spring rates whatever they may be out of either one correct?
Please tell me if Im wrong I dont want to buy springs twice but Im not rich by any means.
RIP Tim. i miss you, buddy
Just because you lower the collar on the sleeve it does not mean that the spring is compressed more. You still have the same weight resting on each spring so no they will not compress more or less.
If you dont want to just go the right route the first time get yourself a set of GC coilovers or Skunk2 coilovers. I myself am going the GC route since Ill be able to customize the spring rates for autocrossing purposes.
So how can you change spring rates? Oh well Ill probably just find some used eibachs cheap.
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
