engine building
Old Dec 28, 2008 | 04:11 PM
JoKiE crx4294's Avatar
popeye built!
^^^^^that was a add on to the other guys post.
Can't spell strength without tren
AAS...It's whats for dinner
Old Dec 28, 2008 | 06:35 PM
civicized's Avatar
Torque wrench, assembly lube, on and on.
You don't learn how to rebuild an engine asking questions on a forum. It is a methodical process, detail and specifics being critical if you want to do it right.
Get a manual and read.
Old Dec 28, 2008 | 08:02 PM
Pete Stop Motor Co.'s Avatar
Well good luck with your build! U need alot of tools and training + experience to build an engine! Yup you could slap it all together in your yard but it wont be a well built engine! Just my .02!
I have a car that poops little rabbits down the track!
Old Dec 29, 2008 | 06:53 AM
Bori300's Avatar
Bori300
Thank you 4 all you guys input.. Yea I kno I'm already on top of the whole studuying thing lol...
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Dec 29, 2008 | 07:16 AM
hondachris1994's Avatar
hatchback1994
When doing a rebuild on a stock motor do new rings still have to b filed or does that only apply to built motors? Sorry for the thread jack, but im also in the process of re-building my first motor. DIY FTW!!!!
Old Dec 29, 2008 | 08:03 AM
rangcrx's Avatar
engine building &best
rings only get filed if they need to be if its a stock motor then the bore has not been changed so the rings will match fine so you dont need to touch them
i love AUTOZONE
Old Dec 29, 2008 | 08:23 AM
  #17 (permalink)
hatchback1994
^^^ what if u are going from say a 9.1 factory piston to a forged lets say 11/1 piston then would u have to file? Im in the process of rebuilding a GSR block with high compression forged pistons and im just tryin to gain all the info possible
Old Dec 29, 2008 | 08:47 AM
  #18 (permalink)
rangcrx's Avatar
If useing a forged piston it will tell you the spec the ring should be. On stock u really only file if turboing
i love AUTOZONE
Old Dec 29, 2008 | 08:51 AM
  #19 (permalink)
rangcrx's Avatar
Just spec them to what they recommend
i love AUTOZONE
Old Dec 31, 2008 | 07:26 PM
  #20 (permalink)
Bori300's Avatar
Bori300
which helms manual should i start out with the service Manual??? Because they have like diffrent supplements and all that
