Cooling fan doesn't run HELP!!!
Old Dec 15, 2008 | 06:18 AM
mtber's Avatar
Get your self a helms manual & start following the troubleshooting steps 1 by 1
Old Dec 15, 2008 | 06:54 AM
freakasis's Avatar
where did you get the replacement fan switch? also heat it up on the stove while measuring the continuity and see if it actually works. i bet it doesnt. basically if you can jump the wires on the switch and the fan works....the swith MUST not be switching! either cuz of a bad switch or theres not enough heat. are you sure the gauge is right? have you checked the thermostat? put the thermostat in some water on the stove and watch it as it heats up you should see it open.
"Black people can't be racist" - Some black guy.
Old Dec 15, 2008 | 08:51 AM
celicagt4's Avatar
TampaBayTunedPerformance
Originally Posted by lmgsr
I have a 95 civic and the cooling fan doesn't run. I checked the fuse and its good, swapped the heater motor relay (which is the same) and it still didn't work, so I ran it directly to the battery and it ran fine so I know the fan motor is good. What could it be. Any suggestions would be great.
Thanks
Ask Coby
xxxhp 35psi LSVTEC 9.2ET 166MPH,
Old Dec 15, 2008 | 11:49 AM
Nandosol's Avatar
Garage Slut
If you keep having issues with it, it could be your wiring/grounds are broken/not making good contact. Buy a switch at autozone($1.50) and some wire, and wire it directly. Put the switch somewhere on your dash. Turn it on every time you drive somewhere.
All for the grand total of 2 dollars.
Enjoy
Old Dec 15, 2008 | 12:30 PM
lmgsr's Avatar
Or O can leave the plug jumped untill I find the issue. Thats what I did until I find out whats going on and fix it.
Thanks
Old Dec 15, 2008 | 12:36 PM
Nandosol's Avatar
Garage Slut
Thanks
Or you can do what I said and be able to shut it off when you want to.
People with race cars hook up their fans to in car switches. just so you know
Old Dec 15, 2008 | 12:52 PM
  #17 (permalink)
lmgsr's Avatar
lol the car is a dd I don't race it
Old Dec 15, 2008 | 02:16 PM
  #18 (permalink)
wearyfurball's Avatar
It may be your coolant temp. sensor. It tells the ecu the temp and then will send info to the fan switch. So your fan switch maybe good and the temp sensor is bad. Had a similar problem. Best bet change them all. Cost just under about 100 bucks for all of them and its worth knowing all of them are brand new.
Old Dec 15, 2008 | 02:33 PM
  #19 (permalink)
juiced2ndgenteg's Avatar
It could be that your thermostat is stuck closed. If the the thermostat don't open the hot coolant cant touch the fan switch(sensor) causing it to turn the fan on. Change your thermostat and I'd bet everything works again. aLSO, The ecu and the gauge coolant temp sensors have NOTHING to do with the fan turning on.
Old Dec 15, 2008 | 02:51 PM
  #20 (permalink)
DC2-R's Avatar
Tyte aRRRRRR
^+1 I had the same issue where my fans wouldnt come on. I jumped the fan switch plug and they came on. Replaced the thermostat and problem solved only like $20 bucks from acura.
Proven Power Dyno Services A++
Built not Bought
