running to rich help
Old Nov 5, 2008 | 07:09 PM
  #31 (permalink)
sleepinsol's Avatar
starting over
Originally Posted by ddp
58 psi is not going to make run rich! have you checked VALVE LASH? 1. if your valves are not to tight .006 intake .008 exaust with the engine cold.2.check your timing3. do a compression test.........
1. not all hondas have the same valve lash settings.
2. if timing is off he will have more problems than just running rich.
3. a compression test is not going to point him in the direction of where the extra fuel is coming from. he said ALL of the plugs were black. if he were down on compression (most likely in 1 cylinder if any) then there would be an oddball looking plug out of the 4.
58 psi at idle WILL make a motor run rich, regardless of the setup. thats just too much pressure at idle. too tight of valves may also make you be down on compression in whatever cylinder the lash has tightened up, but a compression test will not reveal this. to find that out you have to do a leak down.
keep on track with the fuel system. it sounds like theres a bug in there somewhere. o btw. im running 3 fuel pumps cuz im uber jdm tyte yo!
Old Nov 5, 2008 | 07:48 PM
  #32 (permalink)
marktopia's Avatar
TR Balla Donor Supreme
u need a loong vacc hose and go all the way to the map. alot of ppl miss this. my crx with ls did same this and blew black smoke from back. if you cant really figure it out then pm me.
Old Nov 5, 2008 | 08:04 PM
  #33 (permalink)
custom240sx's Avatar
DC Crew Member #1
Holy shit sleepinsol...that must be why you almost threw down 180whp...I knew I should have dished out the extra for a second walbro 255...just having one isn't going to cut it in the honda game anymore lol...but seriously back on topic...check all the fuel line stuff and I bet it IS back by the tank where your issue is. You may as well just drop the tank and check that stuff.
Old Nov 6, 2008 | 05:25 AM
  #34 (permalink)
Stealthracing's Avatar
STEALTHAUTOWORKS
He did say that he had an ls (b1 correct!!!!!!!! i did not say all honda engines have the same valve lash!!!!!JACKASSSSSSSSSSSSSSSS
Old Nov 6, 2008 | 09:55 AM
  #35 (permalink)
sleepinsol's Avatar
starting over
valve lash isnt going to make the car run incredibly rich like he says.......JACKASSSSSSSSSSSSSSSSSSSSSSSSSS.
Old Nov 8, 2008 | 08:08 AM
  #36 (permalink)
D15superman's Avatar
EFsquad
gotta say, this post is epic fail.
Old Nov 9, 2008 | 05:55 PM
  #37 (permalink)
sickef9's Avatar
ok i had blown 120 psi of air thru every line rail,return ,etc.still at 60 psi im at my wits end.any other suggestions?
Old Nov 9, 2008 | 06:02 PM
  #38 (permalink)
freakasis's Avatar
nope, unless you have 2 fuel pumps.
"Black people can't be racist" - Some black guy.
Old Nov 9, 2008 | 06:17 PM
  #39 (permalink)
sleepinsol's Avatar
starting over
buy a new regulator and drop the pressure is all i can think of. either that or ur gauge is reading off.
Old Nov 9, 2008 | 06:30 PM
  #40 (permalink)
freakasis's Avatar
...either that or ur gauge is reading off.
wow, i should have thought of that. do you have another gauge?
