running to rich help
i have a 88 rex with an ls and im running at 58 psi. i have changed everything from feul lines to tegulators in including b&m regulator it just wont go down.i have a stock ecu and a chiped both run the same.if any good sugestions would be greatly appreciated
jsut a ? not trying to make you seem no way but have tou tried to properly adjust the regulator?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
how do u kno itr running rich? have u run it on a wideband or pulled the plugs to check? y not bump the fuel pressure back to the stock setting, and run a stock ecu with no chip. there are TONS of things that could make u run rich. be more specific. setup details are good.
map sensor? im going with sleepinsol...get back to us with more details...hows your oxygen sensor?
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
GTA4
Forza 4
Madden 12
like i said sorry for spelling but i said that i have changed stock regulators and aftermarket plus i said that i have a stock ecu and a chipped one both run the same . i have changed everything that has to do with feul except for the pump,but the regulator should regulate that.and i said that i have a ls not itr or type r or what ever.i also changed plugs 3 times and every time they are black as hell.but thanks
drop your fuel pressure down to stock level which i believe is around 45 psi and see how that does. run it on the stock ecu. do u have any CEL's?
i dont mean to sound stupid but how do you drop it down on a stock ecu and a stock regulator that im using NOW thats what im saying every thing is stock.the only thing that is aftermarket is the gauge and a header everything else is stock.i have a b&m regulator but it craped out on me.
sounds like a clogged fuel return line to me. or a clog in the vacuum line that goes to the regulator. check the vacuum line and see if you actually have vacuum on it at the regulator side. and blow some air in the return line (with the gas cap off) and see if yuou can hear it blowing bubbles in the tank. make sure you have quite a bit of gas in there too when you do that, just to make sure the return line is below the level of the gas.
"Black people can't be racist" - Some black guy.
