Exhaust Ideas
that's a nice traction bar, whether it will help it clear or not, i dont really know i dont mess with the DAs and EFs. as far as ur exhaust goes tho, i noticed you were speaking of getting a flowmaster, please don't there is no packing in there, its just a chambered/baffled muffler and is so loud on a honda. i had the edelbrock sdt on mine for a little bit lol it sounded like a k series race cars all the time. what i would suggest would be to go with a 2.5" exhaust, i think the only reason why they use 60mm piping in japan and europe is because it is like a standard piping size there. by not going 2.5" you would be building an exhaust that will limit you if you may want to make more power later, plus, there's not really any benefit to having such small piping. make sure you use mandrel bends. i'm pretty good with building exhaust systems as i have built many, if you have any other questions and stuff you can just pm me...
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
b. the only difference between 60mm piping and 2.5" piping is 1/8 an inch. THATS IT. that is not going to limit any future power gains. ive seen b series motors with 60mm exhausts make 200 + n/a all day long. if anything it may benifit the powerband of that b16 since the 1/8 of a inch smaller diameter will give a tiny extra amount of back pressure. but that will be minimal if anything. you wont see much a difference between 2.5" pipe and 60mm pipe. mandrel bends are a must tho to prevent bottle necks. if anything youll get the best gains from a good header and a test pipe/higher flowing cat.
yeah, hedman headers suck. I plan on getting a better one after the new years and after they replace the pos I got for the third time. I was looking at skunk2 exhaust. too bad they don't sell just the piping!! lol Skunk2 Mega Power Exhaust 92-93 Acura Integra LS/RS - P/N: 413-05-1525 is this any good?
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
a. chambered/baffled mufflers quiet hondas down. i had a thrush turbo muffler with chambers and baffles and NO pacikng, and all you heard from my setup was the engine. it sounded stock. i also had another one on my old setup and it too was quiet. straight thru ovals with no packing dont quiet anything down any mroe than a fart can will.
no, do you run traction bars without the cross members on ef or da cars?
i guess so, im not sure tho...
btw the hedman header resonator works really well, the header i can't really speak for tho...
ok it's an 1/8 of an inch so approximately 5mm? ok so when some one goes from a 60mm tb to a 65mm (approximately 2.5") throttle body are there no gains or minimal increase in flow? absolutely not, when you increase the diameter by 1/8 of an inch what you are increasing is the volume of your piping throughout the entire system not so much just the diameter in one area. so for an entire system it would equate to a lot less volume in the exhaust system. also, i wasnt saying to use a fart can, mufflers with a good packing material have a tendency to be quieter than those without. i'm not saying yours was not quiet, but for the most part if you buy a muffler (same style as the thrush) with ceramic/stainless packing it is usually a lot less. the dynomax ultraflo oval mufflers are usually pretty quiet and quite durable. it is definitely a much better built muffler than the thrush, hence, the reason it costs more. in addition to that the ultraflo flows a much higher cfm of air than the turbo style because of its internal straight through design. now don't take what im saying as offensive because im not saying that ur thrush is no good, but there are better mufflers out there that offer a much better sound and flow design than it, in my opinion of course. lol i didnt just post up here because i felt like talking, i have built a lot of exhaust systems, and i have actually used the thrush. i dont know what motor you had it on, what size piping you used, or if you had any other resonators (or cats) on there, but i have built a system with that muffler alone and it is not a pleasant sound. and as for those cars with the 60mm piping making 200+ all day, i'll bet they would make more power with a 2.5" system rather than the 60mm.
as for my setup: its an ls vtec. and when i upgraded headers, my exhaust got really loud bc of the fart can i WAS using, and because i had to cut out a resonator to install my header. i then cut the fart can off and clamped to my shitty 2.5" exhaust shop specual exhaust a thrush turbo muffler, and instantly the car was quiet. it sounded stock immediately. and the 20 dollar thrush muffler made more power over a borader range on my setup because of the tiny extra bit of back preassure it made with the chambers. hence the reason when i switched from that system to my 60mm mandrel bent greddy system, nothing really happened except i gained throttle response. which makes sense considering the bends were mandrel instead of crush bent.
no offense taken. i guess there are two different oppinions on the same topic. i still advise using a jdm r header over anyother header besides a high dollar hytech, the hytech rep, or something equivalnt with a 2.5" collector such as a buddy club, smsp, toda, etc... even the ebay knock offs with a 2.5" collector make great power for what they are.
ok we can agree to disagree cuz the discussion is going to turn into one about thermo and fluid dynamics lol. just remember what went in must come out, if you pull in x cfm of air x cfm must come out. there is just as much power to be gained from working the intake side of the motor as there is the on the exhaust side. its all about the venturi or scavenging system, the more you flow out the motor, the more with be pulled from the other runners....
awesome. good advice as far as exhaust size. so, is the muffler on the S2 system shown at this website http://www.advancespeedshop.com/skun...25-p-3257.html a thrush style muffler? I would still like to know whether the center support (the one that runs from the center of the radiator support area to under the center of the fire wall area) is necessary if and when I install some traction bars? lol
