Solve This....No Spark
Old Feb 18, 2007 | 06:20 PM
  #31 (permalink)
CARNAG3's Avatar
ROTM March 2013
like i said, ive tried 3 different harnesses, my original hf harness that worked on my hf motor, an si one i bought from someone, and now the bran new one from honda.
i dont understand though, how my car ran, then changed the motor and now my wiring is bad?
i doubt lht would even wanna look at it, i called them before about my car and they said they dont lioke to deal with cars like that, they only do complete setups from start to finish.
Old Feb 19, 2007 | 09:27 AM
  #32 (permalink)
aznkhmerracernza's Avatar
I hope this helps, but i heard you have a OBD1 Distributor on a OBD0 Motor. What ecu are you running? Well just check your wiring for the distributor and see if they match. Check if the Distributor is mounted in right. Did you try running a Third Ground?
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Feb 19, 2007 | 10:50 AM
  #33 (permalink)
CARNAG3's Avatar
ROTM March 2013
I'm running all obd0.
As stated before, I swapped a friends obd0 distributor and ecu and still nothing. so that rules out your first thought, also stated before , I checked distributor mounting and it only gos one way. Lastly, I checked all grounds for the correct resistance and the are all good....trans ground, valve cover ground, thermostat ground. all fuses are checked and all good.
Please read the entire thread before commenting, unless you have a lot of experience ,chances are you aren't going to be able to help.
If anyone from a local shop is reading this, PM me about me bringing the car to you.
Old Feb 19, 2007 | 04:36 PM
  #34 (permalink)
Damn was trying to help. didn't have to be a dick about it.
Old Feb 19, 2007 | 05:00 PM
  #35 (permalink)
stockCRXsi's Avatar
did you try a different ECU? I read through the post and didnt see you mention you tried this. even though I did see you checked for voltage all over the place. but is one more thing to try when there are no ideas. G/L man. this sucks
Old Feb 19, 2007 | 05:11 PM
  #36 (permalink)
envee's Avatar
Green with Envy
original post says he swapped ecus. tough problem bro. sounds like everything should be working. GL
http://www.cardomain.com/ride/2931273
'06 Mazdaspeed 6
L3-VDT
'02 S2000... Sold
F20c
'93 Civic dx... Sold
B18C1
'95 4dr. GSR... Sold
B18C1 Supercharged
'95 LS... Sold
Originally Posted by shamoo
I have no problems punching a 10 year old in the face if they dented my car with intent.
Old Feb 19, 2007 | 05:42 PM
  #37 (permalink)
stockCRXsi's Avatar
guess i missed it. well good luck anyways.. please update the thread when you do fix the problem so we can know what it was.
Old Feb 19, 2007 | 06:11 PM
  #38 (permalink)
CARNAG3's Avatar
ROTM March 2013
I will definitely let everyone know when its done, Its probably going to be the smallest thing that I just couldnt find in the end.
And really didnt mean to offend you aznkhmerracernza, but alot of people have been telling me to try something already mentioned. Im just really frustrated at this point with this car and just want it fixed.
No hard feelings please
Old Feb 19, 2007 | 07:13 PM
  #39 (permalink)
stockCRXsi's Avatar
by process of elimination, anything from the spark plugs to the connection between the motors' wire harness and cars' wire harness is good. so I would suggest checking every wire from thatconnection in the engine bay up to the computer. or, have you tried replacing the cars' wire harrness?
Old Feb 19, 2007 | 07:28 PM
  #40 (permalink)
stockCRXsi's Avatar
had a friend with a similar problem but on a diff, car. put a B series into A EG, there was a fuse on the inside fusebox that was actually a blank and not a fuse(there was nothing there for the SOHC) but the B series needed a fuse there to make spark and there was no diagram for it. try filling all the empty spots on your fuse box with 15A or 20A fuses to see if that helps. make sure to replace any fake plastic(if any) fuses with real ones. G/L
