Solve This....No Spark
Check your "Aternater solenoid Valve" fuse. It's under your steering wheel, should be a 10 or 15 amp. This is a very common fuse that pop's when you swap cars and it controls the spark. It's worth a shot. G/L -Ben
By the way anyone need a so harness?
yea, i checked, the distributor doesnt even mount up all the way if its 180 off
Isnt there something you have to re-wire at the distributor when putting in a OBD0 B16 into a crx HF?
This is what Id do. Test your good complete distributor/wires on a known good car. Once it is definately established it is good, keep them on your car.
You said its getting fuel. Is the ecu firing the injectors? If it is you know the ecu is seeing some type of cam/reference signal. If not/no signal check your distributor wiring to the ecu(ohm individually).
I think its something between the dizzy and ecu.
Now residing in Atlanta.....
alternator should be fine. It did have the same plug on it, I assume, and nothing was rewired? Otherwise if it was an OBD2 rewired, that could be the issue.
My gut tells me ground problem with the harness. Likely somewhere, somehow, something is not hooked up that should be.
