Solve This....No Spark
i just finished my swap yesterday and had the same problem....
2 things
1 my wire harness that i got off some body rewire the distributor connector for some reason. and i stll havent fiqured out why
2 take the cap off and see where the firing order starts i know it should be 1-3-4-2 but mine actually was 4-2-1-3... when i hooked them up the backwards way and it fired right up
try this its simple and should only take a few sec...
2 things
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
Right on clutch switch. Forgot for a min what the orig post was here.
You can troubleshoot coil and icm grn/yellow blue/white wires, but I'd try to get my hands on a distributor just to pop it on and try it if there is one handy somewhere. If that doesn't work and you are not throwing any codes, I would say it has to be a ground somewhere
2 things
2 things
