Solve This....No Spark
Old Feb 15, 2007 | 08:13 PM
CARNAG3's Avatar
ROTM March 2013
Default Solve This....No Spark
Ok, so Ive been having problems with my car for s while now. Fresh Motor swap and the sob will not get any spark to the plugs.
First off its an HF with a b16a2 all obd0
Heres whats been done:
New coil,igniter,plugs,wires,main relay,cap,rotor
New Si Engine harness from honda
Swapped a friends ecu, distributor,fuse box,wires.
Checked all grounds and measured ohm resistance for good ground
Still no spark.
what now.
Im seriously out of ideas and need this fixed like yesturday.
Any help would be appreciated and If you Can come out and get this car started this weekend you can have a handfull of cash.
Old Feb 15, 2007 | 08:46 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
have you tried systematically checking for power through the whole system?
-as in, start from the ECU wires that go to the dizzy, check for power, then follow the wires, check em at the dizzy, etc. etc.
checked all your grounds?
also, does it crank over fine and just not spark, or are there any other probs/CELs?
**EDIT** sorry, missed the part about the grounds. just saw it.
Old Feb 15, 2007 | 09:00 PM
CARNAG3's Avatar
ROTM March 2013
cranks, spits fuel, no cels, check power plug at dist and was at 12.55 volts
Old Feb 15, 2007 | 09:12 PM
ekhatchboy's Avatar
Redrocket part 2
check your spark plug wires and they are in correct order? had this happen a while bck on buddies h22
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Feb 16, 2007 | 03:17 AM
CARNAG3's Avatar
ROTM March 2013
are you kidding me, I have my wires right, and even if they were completely ass backwords...they would still throw spark.
Old Feb 16, 2007 | 04:04 AM
UF Mech/Aero Eng
yea, they certainly would
i dont want to insult your intelligence, but right plug heat range and gap? god knows ive done it myself...
and you said in the post that you "tried a friends ECU/dizzy/wires", you still didnt get spark? even with a good dizzy and ECU?
and im assuming you checked the clearance between rotor terminal and cap terminals?
Old Feb 16, 2007 | 05:19 AM
CARNAG3's Avatar
ROTM March 2013
gaps are good. it seems to me like a ground issue but I checked the resistance between body grounds . does anyone have a helms or a diagram for the wires going into the distributor? I want to check to see if I'm getting correct voltage through all the wires.
Old Feb 16, 2007 | 06:10 AM
kikwear002's Avatar
TR Thread NAZI
you getting power at the coil?
CarFiche.com | Service Manuals manuals
Old Feb 16, 2007 | 06:14 AM
civicized's Avatar
is your harness grounded at the thermostat housing?
Old Feb 16, 2007 | 06:25 AM
CARNAG3's Avatar
ROTM March 2013
yea, but my engine has two grounding locations, one on the thermoside,and one right next to the that one on the egine where the thermo bolts. maybe I should loop the ground to both points ?
