Need Help Asap!!! Stud Is Turning!!!
Old Nov 5, 2005 | 01:31 PM
95gainfla's Avatar
smokes weed...everyday.
Default Need Help Asap!!! Stud Is Turning!!!
i was rotating my tires in my drive way, when i noticed one of my lug nuts was REALLY hard to turn (even after broken loose), so i sprayed some wd40 on it, and kinda worked it back and forth. I got it to come off almost all the way by KINDA forcing it a little and spraying wd40 on it almost constantly. I got it to the end almost, but not it just keeps spinning and isnt coming off. I think the stud is spinning with it. I know how to fix a stud if its broken, but i cant even get the wheel off to get to the studs. i tried pulling on the tire to put pressure on the stud, and no go.
any ideas? fixes? thanks!
I <3 RooR!!!!!!
Old Nov 5, 2005 | 01:45 PM
Punkinterviews's Avatar
Chavez Motorsports
Yeah, air chizzle! Good luck.....nothing else to really do. Say good bye to the rim though.
Good luck.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Nov 5, 2005 | 01:56 PM
lowoctane's Avatar
Professional Dumbass
keep turning?..can you move the stuf back and forth?..
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Nov 5, 2005 | 02:08 PM
95gainfla's Avatar
im not messing up my SI's!!! even though they all have curbage, i dont want to total them.
unless someone has some rota boost's or slips for CHEEEAAAAP?
im taking it to tire kingdom or whatever tomorrow. i really wanted to fix it myself.
I <3 RooR!!!!!!
Old Nov 5, 2005 | 06:00 PM
NChatch's Avatar
i stepped on my weiner!
Good luck.
unless you have some serious time and skills like me to sand a rim down after using a mad ass air chizzle!!!!!! know what i mean homey!
i had to air chizzle mine off, and to make it worse it wasnt an SI wheel it was an dexpensive ass LENSO drag wheel.
its the only way to do it, unless you can move the lug nut back and forth and break it off, but the depth of the hole in the SI wheel will probably not let you do that.
you cant disassemble the suspension with the wheel on either cause you cant get to the lower ball joint, i tried
good luck
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Nov 5, 2005 | 07:20 PM
sillywhips's Avatar
torch it off its super easy to do it happens all the time take a fine tip on a oxy/fuel torch and eat away the lug nut itsreal easy g/l
shared_pm me if you need any honda swap or repairs done or welding done. in car engine rebuilds in a day like a boss
Originally Posted by rangcrx
trust me the girls like it black
Old Nov 5, 2005 | 07:56 PM
japanbran's Avatar
Bo0st FTMFW
i took my teg to georges tire in new prot richey when mine did that. they fixed it with no damage to the wheel at all. great service up there
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
Old Nov 5, 2005 | 08:52 PM
95gainfla's Avatar
i cant exactly go all the way to new port richey to get a lug nut taken off. ill try tire kingdom or something.
I <3 RooR!!!!!!
Old Nov 6, 2005 | 08:49 AM
95gainfla's Avatar
where can i get a new stud?
thanks everyone. im gonna drill the lug nut, and split the stud in half to get the wheel off.
I <3 RooR!!!!!!
