Need Help Asap!!! Stud Is Turning!!!
Originally Posted by 95gainfla
i was rotating my tires in my drive way, when i noticed one of my lug nuts was REALLY hard to turn (even after broken loose), so i sprayed some wd40 on it, and kinda worked it back and forth. I got it to come off almost all the way by KINDA forcing it a little and spraying wd40 on it almost constantly. I got it to the end almost, but not it just keeps spinning and isnt coming off. I think the stud is spinning with it. I know how to fix a stud if its broken, but i cant even get the wheel off to get to the studs. i tried pulling on the tire to put pressure on the stud, and no go.
any ideas? fixes? thanks!
of the stud to keep it from turning, instead of pulling on the tire (which never did help me).
Second choice, if it can be done; is to come in from behind with mini-vise grips to hold the stud........but this may not work with the Honda design.
Third, try wedging a small diameter (taper the end) steel rod into the
hole with the stud to keep it from moving. Maybe it can be tapped in with
a skinny drift punch and a hammer.......and some patience.-Bob
if it happens again, atleast now i have a few people to help me, and a few more ideas. thanks everyone.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
