car wont start....
Old Oct 5, 2005 | 06:29 PM
crix's Avatar
:mugen member:
Originally Posted by Cold_Beer
Bad dizzy.
I Agree,try another/known good dizzy
Old Oct 5, 2005 | 06:54 PM
dippincrx's Avatar
save the s.o.h.c
hey you the one that got the dizzy from me right, that was a reman dizzy and works perfectly no problems, only got rid of it cause i had no use for it, i check them plugs out and check the pin at teh ecu that had to be placed when you ahd it converted to mpfi maybe it has a bad connection or something, did you solder all the joints, check them to maybe a loose connection, but i knwo it isnt the dizzy for sure. try it on another car if you dont trust me or bring it over i will show you
Old Oct 5, 2005 | 07:02 PM
methree's Avatar
loser x.x
naw man, i know its good because it sparks...maybe the plugs got fouled out or something. if thats not it then i have no clue. im getting spark and fuel..maybe i need to retime my car? i dunno. i had a jdm zc dizzy on there before. i have no clue. the injectors work and the dizzy is sparking, so it should start i imagine. is there a certain side your suppose to put the rotor button on? i dont know if that could be it but im running out of ideas here. joints are fine, the dizzy is sparking consistanltly.
i dont know why people dont take me seriously....now wheres my crack pipe
Old Oct 5, 2005 | 07:35 PM
dippincrx's Avatar
save the s.o.h.c
yes it is possible to get it off 180 degrees happened to me when i swapped a jdm d15 in a crx si and that is why it would start
Old Oct 5, 2005 | 07:40 PM
integra's Avatar
90% grind 10% sleep
check your main relay also---kick your foot up above the clutch to the left a lil and see if it will start
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Oct 5, 2005 | 07:56 PM
methree's Avatar
loser x.x
fuel pumps and spark is there. tomorrow i will change plugs and switch the rotor button.
Old Oct 5, 2005 | 09:27 PM
  #17 (permalink)
Jaso0on's Avatar
Is now ballin!
The motor could have jumped time, take the t-belt off, put it back to TDC, and give it a whirl..
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Oct 6, 2005 | 05:14 AM
  #18 (permalink)
methree's Avatar
loser x.x
and retime it...and put on a new headgasket....and torch the gas tank...
Old Oct 6, 2005 | 05:19 AM
  #19 (permalink)
94EG_Hatch's Avatar
Bad dizzy, 180 out, or not enoughfuel pressure, without a code or seeing it i couldnt say. But after changing a dizzy. Id say Bad Wiring, Bad Dizzy, 180 out or somehings loose.....
Old Oct 6, 2005 | 06:17 AM
  #20 (permalink)
Duke_nukem's Avatar
It maybe a 180 degrees offset.
It has happened to the best of us.
try that.
