Best turbo to run on a DD GSR?
Old Aug 22, 2005 | 12:04 PM
Skittle's Avatar
You Can't Moderate Me.
Smaller exhaust housing=fast spool time,lower numbers.
Bigger exhaust housing=a little laggy,but the power is worth it
A stock Srt-4 turbo has about a quarter sized exhaust housing Explaining why im at 19lbs by 2200rpm ...Thats a example
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old Aug 22, 2005 | 12:13 PM
TurboRotary's Avatar
Mazda > Honda
oh and just so you know.. psi doesnt = power. flow = power. A small turbo at 20psi wont make as much power as a large turbo at 10psi. There are many things to consider when choosing a turbo. Id suggest that you get a little more familiar with turbos before putting one on your car. Learn how they work and what the numbers mean. then choose which one you think would work best for your application.
Honda Know It Alls Hater Crew Member #0000001
Old Aug 22, 2005 | 03:19 PM
Alpha's Avatar
Maybe with a 2" exhaust you will see full boost by 5,300RPM with a T3/T04E 57 trim or SC34E Whoever told you that though was incorrect. If you can afford it I would recommend a Precision GT2871RLE. If you can't afford it I would recommend an SC-5031E. Good luck.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Aug 22, 2005 | 07:02 PM
mtber's Avatar
lead's sc34 was making 7 lbs (full boost) at 4800 rpms on his stock usdm b16 in 2nd gear
Old Aug 22, 2005 | 07:19 PM
Jake's Avatar
dýsfuňctiønal
Thats a big number for a turbo Precision GT2871RLE...
FLeuro
TheCommision
Old Aug 22, 2005 | 07:22 PM
lead's Avatar
I'm Awesome
i found that having sex with your turbo helps it spool faster
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
  #17 (permalink)
mtber's Avatar
Old Aug 22, 2005 | 08:00 PM
  #18 (permalink)
Punkinterviews's Avatar
Chavez Motorsports
I PM'd you back on a price for the custom IC piping.....did you get it?
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Aug 22, 2005 | 08:37 PM
  #19 (permalink)
Jake's Avatar
dýsfuňctiønal
I was about to PM you to see if you forgot about me
But no, i didnt get a PM.
FLeuro
TheCommision
Old Aug 23, 2005 | 09:23 AM
  #20 (permalink)
SloCxHatch's Avatar
No "V-TECH" here!!!
lead doesnt have a sc34.... i do... he has a sc50 which is a smaller turbo
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
