Best turbo to run on a DD GSR?
Old Aug 23, 2005 | 10:45 AM
  #21 (permalink)
mtber's Avatar
Originally Posted by SloCxHatch
lead doesnt have a sc34.... i do... he has a sc50 which is a smaller turbo
Woops got the people/turbos mixed up
I have to look at your logs to see when it was making full boost on the sc34.
Old Aug 23, 2005 | 11:03 AM
  #22 (permalink)
Jake's Avatar
dýsfuňctiønal
He's also running an LS, will that matter? (Compared to a GSR)
FLeuro
TheCommision
Old Aug 23, 2005 | 11:52 AM
  #23 (permalink)
SloCxHatch's Avatar
No "V-TECH" here!!!
lead is also running a b16 and im running an ls. the gsr should spool a tad quicker. id tell you when i get full boost but its to hard to keep the wheel straight and pay attention to gauges under boost. but its around mid 4000s
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
Old Aug 23, 2005 | 11:53 AM
  #24 (permalink)
SloCxHatch's Avatar
No "V-TECH" here!!!
i also have the sc34 31 E 57 trim compressor 76 trim exhaust with a .63 ar
KJ built
ALPHA TUNED
Old Aug 23, 2005 | 11:57 AM
  #25 (permalink)
SloCxHatch's Avatar
No "V-TECH" here!!!
if you cant afford the turbo alpha told you to get Gt2871r then id go with a precision sc50. it will make your power goals and allow some room to grow. but i would listen to alpha.... save yur money and get the gt2871r..... those turbos are just sick!!!!!!!!!
KJ built
ALPHA TUNED
Old Aug 23, 2005 | 12:00 PM
  #26 (permalink)
Jake's Avatar
dýsfuňctiønal
I did a quick search, and couldnt find any specs or prices on it..
Im guessing its in the $1000+ range?
FLeuro
TheCommision
Old Aug 23, 2005 | 12:29 PM
  #27 (permalink)
dscivicdx's Avatar
TR Balla Donor Supreme
cheapturbo.com has them for $1175
Old Aug 23, 2005 | 12:49 PM
  #28 (permalink)
SloCxHatch's Avatar
No "V-TECH" here!!!
talk to alpha on here... e knows his shit... he will set u up right.....
KJ built
ALPHA TUNED
Old Aug 23, 2005 | 03:30 PM
  #29 (permalink)
Alpha's Avatar
I heard that Alpha guy drives a Yugo
This is a GT2871R with a T25 inlet. It's on an SR20DET now. When I drove the car response was incredible.
This is a GT2871R at 20lbs on a B18c1 with the smaller A/R turbine housing.
This is another GT2871R at 24lbs on a B18c1 with the larger A/R turbine housing. The duty cycle on the injectors was at 95%. Jeff Evans had to detune the higher rpms to not make as much power. With more fuel, this could have easily made 450whp.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Aug 23, 2005 | 04:51 PM
  #30 (permalink)
Jake's Avatar
dýsfuňctiønal
Damn, i dont plan on pushing anywhere near 20 pounds haha.. Since its the stock block, ide run maybe 8-9psi daily.
FLeuro
TheCommision
