RevHard 02 Si whp ?
With all these members mentioning a weak shortblock, i would worry about what its limitations are more so than the #'s you want to reach. Find whatever the arguable reliable limit is and use that as maybe a high boost setting and drive around on low boost whenever possible. That is unless you got the $$$ for another shortblock. k24 from a tsx sounds like a nice replacement
I'd also stick with the conservative a/f. Best of luck with it.
02 WRX
K&N, ic hoses, up-pipe & turboback
02 WRX
Well the ones that are breaking have a little over 300whp. But then again there are some that are running 340whp with no problems so far. Check this out. http://www.ephatch.com/forum/showthread.php?t=64167
