RevHard 02 Si whp ?
I am going to be getting this thing tuned next month. I was just wondering what all of you think what the whp and tq are. My mods are k20a3 with revhard turbo:
revhard manifold
t3/t4
revhard intercooler and piping
440cc injectors
Kpro ecu
stock tranny
I hope for at LEAST 250whp.
revhard manifold
t3/t4
440cc injectors
Kpro ecu
stock tranny
you should definetley make that much power, especially with k-pro, what size DP, and exhaust are you running? that will be a key factor.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
It'll be tuned for 10psi.
I was thinking of bringing some race gas(unleaded), and have them do a tune for that also.
I am running real rich right now, and my duty cycle is a little high. Hopefully, tuning will bring it down a little.
Guest
Posts: n/a
You will not need any race gas at 10psi.
im dumb -
So it would be safe to assume, 250whp is easily made from a t3/t5 57trim, on 10psi.
I don't recall what the 02 Si's rev to. So I guessed, Im not about to do a lot of research on it.
im dumb -
sounds purty good, but remember 250fwhp is nothin when its not in the good power band...ie 6-8xxx rpm. that was my buddies problem, when he finally pumped up the boost he was makin over 400whp on the gsr but not until like 6500 and up, which does nothing for you when you think about it, b/c ur shifting at 8-9000.
