RevHard 02 Si whp ?
Originally Posted by mikebish86
sounds purty good, but remember 250fwhp is nothin when its not in the good power band...ie 6-8xxx rpm. that was my buddies problem, when he finally pumped up the boost he was makin over 400whp on the gsr but not until like 6500 and up, which does nothing for you when you think about it, b/c ur shifting at 8-9000.
with 10 psi you should easily see 250 wheels. if i were you, id find a type s or a type r head, the cams and vtec should help you a TON in the top end....
The crank and rods are crap. I would not take it over 300hp. That seems to be the breaking point of the a3. If she does blow, then ill have to put the k24 bottom end in there. That would be stronger and a tq monster.
