This is what you get for $1599.
Old Mar 24, 2005 | 10:42 AM
qitstrn's Avatar
Can you spot me 20 cars?
Default This is what you get for $1599.
These are my new driveshaft.com stage 5 axles. Good for up to 900hp. Look in the second picture and see the difference in the axle nut. That pic tells all. Hopefully this will be my last set of axles. The ring gear is on it's way. Once it's here i will post pics of the whole set up and the price of what it will take for me to achieve my goals of single digits.
Old Mar 24, 2005 | 10:49 AM
60-1EK's Avatar
Engineer at the source
http://www.driveshaftshop.com/item159054.ctlg
They are only good to 800hp. Also, the nuts look wack. I need to trim the end of my axles so that my ITR center caps will fit over the opening in the rim, but my axles have been on the car for a while and I don't wanna remove them. Those axles should hold, but keep your receipt cause I know people that still break them.
Did you get the ring gear or did you get the tranny cradle?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 24, 2005 | 10:55 AM
qitstrn's Avatar
I have heard 800-900hp. I think it's 900 at the crank or 800whp. I was told these axles wont break on a 26 inck slick. If they do i can get them covered under warranty. Why do the nuts looks wack? The stock one is hammered up but only there for a reference to how much bigger the new ones are. I also forgot to mention this set up does also come with new hubs to fit those monster splines but they are already installed on the car. I ordered the prodrive ring gear. Hopefully that will work and it will hold togther.
Old Mar 24, 2005 | 11:11 AM
60-1EK's Avatar
I have had the same setup on my car for a while now. I wasn't referring to your nuts looking wack(lol..read that again). I was saying that the DSS nuts look funning on my car cause they are so big. That prodrive gear is bank. All in the preloading.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 24, 2005 | 11:17 AM
qitstrn's Avatar
I have the same setup on my car for a while now. I wasn't referring to you nuts looking wack(lol..read that again). I was saying they look funning on my car cause they are so big. That prodrive gear is bank. All in the preloading.
I see. That sucks you have to cut your caps for them to fit. Do you have a upgraded ring gear yet? I'm tired of breaking.That is why i held out on not going back to the track untill i got mine. Hydro trannys are getting expensive.
Old Mar 24, 2005 | 11:43 AM
60-1EK's Avatar
I actually have to cut the ends of the axles....they protrude out like 2 inches from the end. I am still running the OE final. Knock on wood, since I machined the teeth off most of my ebrake to use it like a staging brake...no breakage for me yet. Breakage sucks. good luck.
Btw, did you just get the ring gear, or did you also get the countershaft with it?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 24, 2005 | 11:49 AM
qitstrn's Avatar
i got the countershaft with it too. I'm getting Frank@Sfp's old set up.
Old Mar 24, 2005 | 12:27 PM
F4A22's Avatar
Old School
$1599!!Holy crap i dont even have that much into my car including the price....You gotta pay to play hope they last for ya.
Old Mar 24, 2005 | 12:55 PM
4dorteg's Avatar
Allan works as well
Nice Ron, good luck and hopefully they wont break
TR salesman..........
Old Mar 24, 2005 | 01:56 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Looks good.... Once this motor is done and I build up some more funds, I will be getting a set
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
